Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
Standard Ford 6 cd changer - error code E 3 !!
Old Sep 8, 2005 | 08:04 AM
theblackmondeo's Avatar
theblackmondeo
Default Standard Ford 6 cd changer - error code E 3 !!
Hi everyone,
I have just bought a 2.5 V6 Mondeo Ghia X, which has a 6 cd changer unit installed in it - supposedly you press LOAD, and then a message WAIT appears, and then allows you to load in up to 6 cd's.
I've pressed LOAD, and it does comes up with WAIT, but then says CD ERROR E3
Does anyone know what this error means and how I may go about fixing the problem ?
Thanks in advance
Simon
Old Sep 8, 2005 | 08:26 AM
Shanny's Avatar
Shanny
I had the same problem. When I bought a Galaxy, the changer had two CD's stuck in it and an error was displayed. I took it apart and got it working but the same thing happened.
I found out after that this is a common problem when the battery goes flat with discs in the changer. As far as I can tell, the changing mechanism can't find a home position and becomes misaligned.
You can try taking it aprt and having a look or doing what I did. Ford wanted about 250 quid IIRC. A smaller local firm did an exchange unit for 120. I replaced it about 3 years ago and it's been fine.
HTH
Shanny
Old Sep 8, 2005 | 08:44 AM
theblackmondeo
Hi Shanny
Thanks for the advice - I did ask the guy who I bought it from if it all worked ok, and he said " far as I know " ... nevermind
I'll see about sourcing an alternative changer like you say - Ford's prices seem a tad high to say the least ...
Simon
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
JasonPD
21
Aug 20, 2015 07:36 PM
muz
Aug 16, 2015 12:57 PM
