Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
Subaru boost control
Old Jun 28, 2011 | 09:36 AM
chaffe's Avatar
chaffe
Turbocharging Technician
Default Subaru boost control
Sorry for the non ford question!
Ive asked the question on a subaru forum, but My general thinking is that they dont have the vast members and knowledge that we have on here, so here it goes; The car in question is a 2002 impreza WRX,(ecu controlled boost)
After putting the cat back on my car it is running less boost, understandably there will be a small restriction now in the exhaust, but IMO this should not decrease the boost. As i see it the ECU will want to achieve target bost of 19 psi (as before) And so should bled off enough air unril this boost is reached, regardless of backpressure. As a test i bypassed the factory boost controller and used a bleed valve, and yes the car can pysicaly run 19 psi in this manner. So my next train of thought was that i may need to "help" the factory bleed valve as it prehaps cant flow enough now, so i installed a restricor from the compressor housing, no change.
This leads me to the conclusion that somehow the ecu thinks it is reaching target boost, so i can only assume that the ecu does a calculation through the air mass meter? Or is there a seperate map sensor for this? thanks in advance.
Old Jun 28, 2011 | 04:12 PM
JOHNDQ's Avatar
JOHNDQ
Do you have the Bosch air flow mater mate?
Old Jun 28, 2011 | 07:53 PM
domino's Avatar
domino
is the restrictor pill still in the pipe work to the boost solenoid ?
Old Jun 29, 2011 | 10:27 AM
chaffe's Avatar
chaffe
its pipes as follows; pipe from compressor to "T" pipe out of "T" to wastegate. Third barb on "T" has pipe to solenoid valve, with a plastic "joiner" in between, is this the pill you speak of?
chaffe's Avatar
chaffe
no idea
Old Jun 29, 2011 | 07:03 PM
domino's Avatar
domino
look down the end of the pipe work and in one of the pipes at the solenoid end there is a tiny pill (ball bearing looking) with the center drilled out,,,,sounds like its missing or you need another pill with a diffrent size hole,,,,if your running a boost controler then this does the job of the pill anyway,,,the smaller the hole in the pill the more boost you will run,,,so if its missing you will be running low boost
Old Jun 30, 2011 | 06:05 AM
chaffe's Avatar
chaffe
surley if its at the solenoid end you will need a bigger hole for more boost? as the more you bleed off the more boost you will make? Ill have a closer look later, its just strangethat it made 19psi before no problem at all, and now is making 14-15psi, the general concensus on the subaru forum is that it is now outwith the mapped duty cycle of the boost control solenoid and it cant run enough duty cycle to make target boost. A manual controller will sort this out lol.
Old Jun 30, 2011 | 06:35 AM
chaffe's Avatar
chaffe
Found this picture, the pill is at the compressor end as i thought, ill have a look see if its fallen out or needs to be smaller later (ive been interfering in this area lol.
Old Jun 30, 2011 | 02:51 PM
domino's Avatar
domino
iv always found the pills at the solanoid end but it doesnt realy matter as long as its in the pipework
Old Jun 30, 2011 | 03:08 PM
chaffe's Avatar
chaffe
It does, take it to the extreme;
Almost block the pipe to the solenoid= low boost (no matter what the solenoid does, the wastegate will open)
Almost block pipe from compressor to "T"= high boost (if the solenoid is open even minutly it will bleed off ALL avaiable air, resulting in high boost as the wastegate will not open.)
Unless im not seeing it right?
Old Jun 30, 2011 | 08:10 PM
domino's Avatar
domino
your right brain wasnt in gear as im used to working with the 3 port solanoid mostly
Old Jul 7, 2011 | 06:39 PM
c14aff's Avatar
c14aff
Just burn the old girl cuz!
Old Jul 8, 2011 | 06:41 AM
chaffe's Avatar
chaffe
its ok mate, ive just recieved pink sti 550cc/min injectors and im away to get a td05 20g turbo and programmable ecu for about 360 bhp
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
