Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
Non Starter
Old Dec 26, 2007 | 09:54 AM
trev27's Avatar
trev27
Default Non Starter
Hi, hope some of you techno wizzards can help me!!!
I have a 1998 escort GTi, when i turn the ignition key (or press the starter button) there is no power going to the starter motor!! The dash lights are working fine, all other electrics are ok!! After a few minutes or so it will start as normal and run fine!! Its been doing that a few weeks, but now the fuel pump is not priming, the car has fuel in the tank. It has not started now for a few days (luckily i don't it yet) although when the engine turns over there is no fuel to start because the fuel pump is n't priming. Any ideas anyone???? Is it a battery earth fault, fuel pump (do they just stop working without any warning??), Starter motor, fuse box??? Anybody else had a similar problem and sorted it???
Cheers for any help
Trev
Old Dec 26, 2007 | 10:11 AM
gkandr4ch's Avatar
gkandr4ch
Has the fuel pump inertia switch self activated? Located behind the drivers footwell cover. Push the red button down on the top of it.
Old Dec 26, 2007 | 11:19 AM
trev27's Avatar
trev27
Hope, thats ok, its down!! Checked wiring and there does n'tappear to be a live to fuel pump!!!
Old Dec 26, 2007 | 04:18 PM
phill295's Avatar
phill295
ino the battery to cables are a weak point as have changed a couple if you have a multimeter you could check the resistance in the cables and see how much voltage the starter is actualy getting also check the fuel pump relay make shore you can hear it click .
hope any of that helps
Old Dec 26, 2007 | 04:53 PM
trev27's Avatar
trev27
Theres a click when i turn on the ignition.
Old Dec 27, 2007 | 11:38 AM
trev27's Avatar
trev27
There appears to be no live to the fuel pump!!
Checked this by tapping into the wires to fuel pump and checking with a mutimeter, igntion on, nothing, ignition off nothing! That was on the viloet/Orange wire and the white wire, there are 2 other black wires which
i am thinking are earths!! There is aclick from the relay and the engine turns over, battery seems to be ok!! Is this a PATS problem?? If so. what is the cure?? Thanks for any help.
Old Dec 27, 2007 | 12:57 PM
phill295's Avatar
phill295
you could try tracing the fuel pump wires back as far as poss and see where it is losing the power also try another pump relay just incase ok
hope it helps
A.t.p
Oct 23, 2015 07:54 PM
cossie362
Oct 11, 2015 03:53 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
marky_g
Sep 12, 2015 04:26 PM
