12" RE Audio SE12 V4 Sub and Kenwood KAC-9152D Amp
Im selling my RE Audio SE 12 V4 (if you know sounds, you'll know this is a VERY good sub!), rated at 600W RMS, dual voice coil sub.
Im also selling my Kenwood KAC-9152D (900W RMS) D Class Mono amp.
Both are in good condition with a few marks.
To get the best from the sub, you'd ideally need a box like this:-
Change of plans forces sale.
im open to sensible offers - they are about 6 months old, and havent been used to the full extent they're capable of.
I'll sell seperately, or together.
KAC-9152D main features:
1,800 Watts max power
500 Watts x 1 max (4 ohms) RMS
900 Watts x 1 (2 ohms) RMS
900 Watts x 1 (1 ohms) RMS
Wired remote control to adjust boost level and frequency included
'Dual mono drive' configuration option (requires two KAC-9152D amplifiers & specialist knowledge!)
Aluminium die-cast heat sink
Detachable aluminium top cover
All connections on one side for easy multi-amplifier installations
Built-in Variable Low-pass Filter 50-200Hz (24dB/oct)
Built-in Infrasonic Filter 15Hz/25Hz (18dB/oct) to cut unwanted ultra-low frequencies
'Kenwood logo triangle' design power indicator LED
1 ohm stable
Gold plated RCA line input & line output terminals
Speaker level input option. RCA line outputs
Power MOSFET switching power supply
'D' class amplification circuits throughout, using switching techniques instead of the linear methods used in Class 'A' or 'B' type amplifiers. Class 'D' is a significantly more efficient than Class 'A' or 'B', resulting in greater power with less heat generation, higher stability and improved reliability
2 x 30 amp power supply fuses
Sub info.
* Fs – 25.1Hz
* Re – 2.8dvc
* Qms – 4.5
* Qes – 0.49
* Qts – 0.44
* Sd cm2 - 480
* Vas (litres) 171
* Xmax (1-way linear) – 18mm
* Bl – 17.7Tm
* SPL 1w/1m – 86.1dB
* RMS – 600w
* PMPO – 1000w
* Cutout – 11 1/8”
* Driver Displacement – 0.15cuft
* Mounting Depth – 6.75”
* Weight – 10kilo
# 600W RMS / 1000W Peak
# Dual 4 Ohm
# Dual composite 2 piece cone
# Rubatek foam surround
# Cast aluminium basket
# Tork-Tite terminal
# 4 layer flatwound aluminium voice coil
# FEA optimized TG technology motor structure
# Triple stack magnets Progressive spider
# Wrap around rubber gasket
theres a mark on the rubber surround on the sub - i'll take £250 for the pair + post
1 ohm stable
Sub info.
* Fs – 25.1Hz
* Re – 2.8dvc
* Qms – 4.5
* Qes – 0.49
* Qts – 0.44
* Sd cm2 - 480
* Vas (litres) 171
* Bl – 17.7Tm
* RMS – 600w
* PMPO – 1000w
* Cutout – 11 1/8”
* Weight – 10kilo
# Dual 4 Ohm
Tank Mike
Ford Focus ST Parts for Sale
18-05-2016 09:38 PM
siscossie
27-08-2015 09:27 PM
muz
16-08-2015 12:57 PM
