Old May 8, 2008 | 10:06 PM
RAT8OY's Avatar
RAT8OY
Originally Posted by rallyst
Could possibly be a worn wheel bearing, best way to test for this is to jack the drivers side front wheel free of the ground, place a hand top and bottom of the wheel. Push the top away from you and pull the bottom toward you. If you get any movement, it likely the wheel bearings are worn. It could also be a brake cylinder seized, as I had a car come in a few weeks ago with a similar problem, caused the pad to always be in contact with the disc. Best to get that checked out at a garage. All the best, Chris
Very true on the wheel bearing fault, but I have had several on their way out and no movement in the wheel (well by hand anyway). An old boy told me to spin the wheel and put your ear next to the bearing and listen for a slight crumble noise and you can sometimes almost feel it on the wheel as well as you spin it by hand, this is the first sign its on its way. Obviously the noise is louder whilst under load!
