Trader Group Buys This forum is where our registered traders run their group buys. Come inside and sign up for a bargain.
L8/P8 Convertion bracket to allow fitment of ECU to 2wd Sierras. [Group Buy]
Old 09-10-2012, 10:44 AM
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
Default L8/P8 Convertion bracket to allow fitment of ECU to 2wd Sierras. [Group Buy]
Another great group buy.
For those of you who dont know what it is, it is a bracket to secure the L8 or P8 in your 2wd car properly the same way the L1 or L6 was, with screws. It essentially converts your L8/P8 case to have the L1/L6 wings on it.
As any of you who have converted a L1 or L6 ECU to L8/P8 will know, the ECU ends up flailing around loose as it doesn't mount into the standard L1 and L6 mountings properly due to having no side lugs, well this item fixes that problems. It is also useful to any owners with the L8/P8 that wish to mount them to a flat surface properly, IE: MK2 escorts, RS Turbos etc.
This product is in stock now. These retail at £20 inc vat but for 5 or more buyers I will supply them for £18. For 10 or more, £16.
Postage will be an additional £3.50 for 1st class recorded.
If you are interested, just add your name to this topic stating clearly that you wish to be a part of the group buy.
Members confirmed so far:
Old 17-02-2016, 09:26 PM
Ridgey
Ridgey's Avatar
Stu
Do you still sell these ?
Cheers Ridgey
Old 18-02-2016, 08:17 AM
Yes pal:
http://shop.motorsport-developments....cket-967-p.asp
Old 18-02-2016, 01:32 PM
Ridgey
Ridgey's Avatar
Ordered thanks Stu
Couldn't see them when I looked.
Old 18-02-2016, 01:40 PM
Guinnless
Guinnless's Avatar
These are a good bit of kit and I have one fitted to mine.
If you've got an encryption board makes sure that the lid doesn't push on the chip when you slot the ECU back into the 2WD mount. The 2WD mount is a very tight fit!
I used thin double sided tape on underside edge of the lid to give it a mill or two of clearance.
Old 18-02-2016, 06:28 PM
Ridgey
Ridgey's Avatar
Cheers for the tip
Old 18-02-2016, 06:40 PM
costina
Live long and prosper!!
costina's Avatar
Just ordered one too.
Old 19-02-2016, 10:35 AM
Ridgey
Ridgey's Avatar
Speedy delivery too
Thanks Stu.
Old 26-02-2016, 07:10 PM
siscossie
3-door moonstone
siscossie's Avatar
Old 01-03-2016, 03:55 PM
siscossie
3-door moonstone
siscossie's Avatar
Arrived today cheers stu fast delivery cheers
Old 05-01-2017, 09:32 PM
Rs(555)
Rs(555)'s Avatar
Received mine today 👍
Forgot to add the discount code 🙈😂
jonfoc (25-10-2019)
09-10-2015 07:38 PM
155lee
14-08-2015 11:21 AM
RsS2daz
14-08-2015 05:26 AM
adam151082
11-08-2015 04:50 PM
lockie
31-07-2015 10:03 PM
Quick Reply: L8/P8 Convertion bracket to allow fitment of ECU to 2wd Sierras. [Group Buy]
