Billet rear hubs Cossie 4x4
What is the reason for fitting billet rear hubs on an otherwise standard setup, is there a significant weight saving?
The O/E one's are quite heavy so there must be a decent weight saving. I'm not sure if the billet ones have the 6 deg shims built into them, if they don't then it would make sense to have them as it'll save a good chunk on a 6 deg beam.
Oh, received your parcel today too Toby, cheers. Will text you tomoz
Thanks Dave. I don't think the six degree is built in, I have a 6 degree coming so wouldn't want to duplicate but I am all for saving a few kgs.
Glad the parcel got there, sorry that they are not 100% intact, the tiger seal was too strong but at leat you should get the size of what I need.
I put the signs you made on recently, fantastic job, thanks
MONSTER (13-01-2017)
Thanks for such a detailed technical answer lol
I was thinking the same, nice to have but no real benefit. I am only considering as need to remove mine for the new beam....if mk pulls his finger out and delivers
cossie fan (unluckerly)
It's less un sprung weight
Will in turn means when you hit a bump
And your wheel goes up , the momentum has less
Weight to push back down so your car should
Handle better , whether you will notice it or not
Is another thing
Is another thing
As you say, you may not notice it but I do believe it all adds up.
My first car was an mg metro, I guess it made 70bhp on a good day, maybe 90? And if you took a normal 12 stone passenger you could definitely feel it being a little slower, fill it with 4-5 teenagers and you could feel the brakes struggle, bottom out the suspension over bumps and you would have to change down to 3rd or 2nd up big hills...100kg saving over the whole car has a big effect.
I've just bought a pair of these
http://anembo-engineering.mybigcomme...d-finish-pair/
When you consider the cost of new bearings and the time it takes to properly clean and paint the original hub carriers it's a no brainer
Plus they look nice !
These are CNC machined from T6 aluminium so they are a lot lighter than the standard items and very strong. They also have extra wall thickness for strength.
Ideal for motorsport/rallycross, fast road use, kitcar applications as well as standard road going cars.
These look absolutely superb fitted. supplied anodised in red, blue, black, gunmetal grey or gold.
They come with wheel bearings already fitted and brand new. These alone cost Ł85.00 so please take these into account with price.
Please feel free to email with any questions
Sounds like excellent value to me. Plus the old hubs with bearings probably have some value to them to sell and cover some cost.
Think I will get a pair
