Mk1 Sierra XR4x4 Vacuum Hose Diagram
Hi All,
As above, would anyone have a diagram showing the layout of the vacuum hoses on a Mk1 Sierra XR4x4 2.8? Either that or a good clear pic of the engine bay that I could work from.
Thanks Craig.
Thanks Craig.
Hi Craig
Flick me a text on 021 1212193 and I will get in touch with you. I am on overnight shift at the moment so sleep at various times hence not getting you to ring me. I have an old XR4i in my driveway that I am sure will be the same as yours and you are welcome to come and have a look in Titirangi or I could possibly get some photos if I know what bits exactly you are after. Cheers David
Would the photo you require happen to be where three vacuum pipes connect to a fitting at the top manifold housing?
Hi Craig
I sense a gathering of the Auckland Sierra clan
Awesome, thanks for the photo, that gives me some of what I need. I dont suppose you could give me one of a little bit further back aswell where the vacuum hose that comes out of the firewall on the drivers side goes to and also that general area?
Im feeling a bit silly as I did mark everything before it all come apart 6 months ago but when I cleaned everything I accidently removed my markings
I'd be keen for a bit of a gathering when I'm up and running again.
Cheers.
Cheers.
Although Craig has got it sorted now I will put up this diagram of how mine is plumbed in case someone comes across it in a future search. David
http://i377.photobucket.com/albums/o...psblyb9yqs.jpg
oldschoolfordnut
164
08-09-2018 03:00 PM
155lee
17-04-2016 02:01 PM
