MK5 Fiesta anti-roll bar bush change
hi all
or is it a mk6 2006?
is it possible to change the anti roll bushes on an 06 mk5 1200 fiesta without dropping the cross member? I have a bad clonking on bumps but its not the top strut bearing or the ball joint or links as they are all new,
Fiesta MK5 anti roll bar bush replacement
I am also curious how to replace the anti-roll bushes on my 2003 MK5 1.4 fiesta. The book mentions dropping the cross member but surely there is an easier way to do this. I can find nothing on Youtube or any blogs on how to achieve this and after 18 years since this model came out hasn't anyone had to change their bushes? I see the original post has not been answered so am adding in the hope of a response now. Thank you.
hi know its an old post
has anyone changed the anti-roll bushes without dropping the sub frame ?
or is there a video out there of how to change the mk5 fiesta anti-roll bushs
thanks
thanks
Should be the same on latercars - On the mk3s we used to remove the front bolt on the D bush, then loosen the rear bush as much as you can with a spanner.
Long crow bar/pry bar and bend the arb bracket, squeeze in the new bush, then bend the bracket in place with water pump pliers.
thegoat (21-02-2022)
any one got the part numbers for the sway bar bushings, my bar is 19mm ans i can only see heavy duty ones with 19mm inner
changed the drop links and the noise is still there so I need these 19mm inner bushes
just an update, i didn't change the anti roll bar bushes
had a noise when driving over bumpy roads the noise was a plasticee noise not a metal type of noise
changed the drop links still noisey (didn't expect it to fix it)
changed the front strut top mount & bush noise stopped at the moment
