Cosworth fuel rails
Cosworth fuel rails
Hi All
I'm on with a mk2 YB Install and My fuel rail/reg pipes are quite small ?
I was intending to use 8mm fuel pipe for feed and return !
Are there different fuel rails with slightly bigger pipes I'm sure I used 8mm pipe on another YB conversion I did ?
Thanks Paul
Thanks Paul
I've a blank canvas so can use anything to fit my rail within reason
Cheers paul
I would only need to change my tank return as that's -8 at the moment ,
One more thing any idea why someone would go to the trouble of welding the 2 halfs of the inlet together ????
I've bought a replacement one, But I wonder how much boost someone ran to require welding it
The metal fittings will be slightly smaller, but that is the ID of the flexible hoses.
A far cry from 6mm that is used for the factory 8mm OD hard nylon line to press over.
cossie fan (unluckerly)
as I say above I'm not sure if -6 is the same or larger than standard size but more than enough for most people's needs on a yb
That's usually why I do it
Got another question to keep you fellas busy ? I've ditched the welded inlet and painted a old 2wd saph one I had , only to find the front mount of the rail doesn't line up with the lug on the inlet
So am I right in thinking I really need a 2wd rail to match my inlet and I'm guessing my original was off a 4wd or even a escort ?
I can make up a bracket to hold the rail as it will line up with one of the other bolts so it's not a big problem really ! Just another job that takes twice as long as a thought
2wd and 4wd rails are different, so presumably intake where they mount is different too.
As for the welding, it does seem a strange one.
