MKII 1.8tdci - squealing noise, turbo???
I have a MKII 1.8 tdci on about 137500 miles that has recently started making a squealing noise coming from the back of the engine in the direction of the turbo. Its just had some pipework for the cooling system replaced due to leaking and initially I thought this issue was going to be the water pump, hence this would perhaps resolve the squeal, but it turned out the pump was fine and the squeal is still present.
I've had some discussions with the mechanic about likely scenarios if it is the turbo and have found various references on t'internet to oil starvation, possibly linked to failed oil seal on injectors but I really need to find out whether this is a common problem and whether it could be something else that is more easily resolved (and cheaply!) than replacing the turbo!
The squealing happens on startup when revving and generally while driving, but not always! Sometimes its nice and quiet whether under load or not. I have seen one internet reference to a perished pipe causing tape to be drawn into one of the nozzles and causing the noise so don't know whether this is really a possibility? The sound doesn't really sound like a failing bearing.
Driving wise it seems fine but I'm not trying to rev it too much just in case. I'm also worried about doing too much driving in it, in case things go bang!
Any suggestions?
Any suggestions?
JK12
33
26-04-2021 12:09 PM
Matt Baxter
16-09-2015 08:30 PM
muz
16-08-2015 12:57 PM
