Turbo surge ? What is it and a it bad ??
When I come on boost it's like a miss fire but turbo boosts up. When I let of the turbo chatters like mad. Anyone have any ideas ?? Is surge bad cheers ppl
Compressor surge...ie the fluttering noise is bad.
It is basically air trying to go out backwards through the compressor....when it really shouldnt be.
That can be due to having no dump valve when you let off, or because the engine cannot consume all the air the turbo is trying to squeeze in under load.
Compressor surge and stall happens in all turbines, so turbo, jet engines etc.
It happens due to the compressor trying to force too high a capacity of air for the chamber to accept. This is normally overcome by means of a bleed valve on jet engines to allow excess air to escape, as if you allow this to happen it will cause early fatigue of components and also very inefficient running. Although it will not cause immediate damage, it will cause excessive wear eventually.
If you look up compressor surge and stall on google it will shed some more light for you.
Matt Baxter
16-09-2015 08:30 PM
