Central lock problem on Sapp Cosworth..?
Hi .. may need a little help on this .. one morning I came out to my 88 2wd Sapp. Cos. and it was dead .. battery flat. I put on my spare batt. and Car started fine, took it out of my garage and left it with engine running ... but after a short while there came a "buzzing" noice from the left side of the car and about 30 sec's after the same on the right side ... I switched off the car but noice was still there, .. I pulled the fuse for the C-locks and it stopped. I've tried to look a bit at it but no luck solving it yet ??
As I read the wiring dia for a 88 2wd Cos, there is no relay... only a wire from batt via a fuse to the 5 locks .. does that sound correct .. ?
rsguy
44
29-09-2015 03:29 PM
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
