1.4 cvh not starting, nothing there at all.
Having issues getting my brothers car started, there is just nothing at all when we try and start it,just a click from the ignition and that's it. Checked the connections on the starter and they seem fine,
it was running a few year back but after that it just made a fast clicking noise like a machine gun but not there is nothing,possibly a starter motor fault do you think? it's a 1.4 cvh.
my 1.4 orion sufferd the same sort of fault (starter motor) id normally shock mine accross the 2 terminals with screwdriver etc not the best soloution but it worked at the time lol. replaced the motor and it hasnt bein bad since.. is the battery good? the machine gun sound is normally not enough charge to fire the car
Battery or starter definitely try giving the starter a good clack with a hammer and make sure the battery is fully charged. Sounds like the starter is definitely sticking!
when was last time car ran?
if it has sat for a long while the hydraulic lifters can become soft and wont open the valves.
battery got enough juice to turn engine at right speed as well as give a spark.
check for a spark at plug leads first,
if spark check fuel, is the fuel old?
if so drain and renew.
may need a tow in gear to pressurise the lifters or put it on a starter charger to get them filled with oil.
vdun01
Ford Fiesta
05-10-2017 08:14 AM
