cvh efi setting base idle
Found a guide for it (on here i think) but having trouble getting it to idle with the iscv disconnected.
I've even tried using the Ford star tester, but gets to code 60, revs die then stalls, so don't get chance to adjust, the screw is also almost all the way out.
i've got no air leaks, new tps,iscv,plugs,leads and coil.
Its the later efi with the iscv on the manifold if that makes a difference.
JK12
33
26-04-2021 12:09 PM
3dr cossie
Alloy wheels and ICE for sale
02-09-2015 08:58 PM
