sierra cosworth 1986 starts but wont rev
hello, i have a 1986 sierra cosworth that will start, idle, but just wont rev, its recently had a full engine rebuild with forged pistons, everything is new including ecu, loom, injectors, sensors etc.. and has had many master mechanics pickled and would like opinions from people who know about fords so ive decided to try here oh and i was wondering if anyone else has come across this problem, cheers.
Liam.
P,S car is god damn curse
Liam.
at a guess cos aint seen what your car is doing but has it got the correct chip in the ecu for the spec your running?? and as above take it to a pro if all fails
its funny because when we brought it into the garage i work in, im only 19 but i did the engine re-build my self and i know its perfect, but once the car was back together, it started and was running lovely, and then a guy who was helping out who i work for accidentally crossed a spanner from the number one injector to the chassis, and it started running crap so we switched it off and it would never start again, but what we didn't realise is that it fried the ECU, but we didn't know this at the time, at closer inspection we found that number 1 injector was stuck open while cranking it, so we changed the injector and checked the others all squirting perfectly in order(this was after we changed the ECU, chip and rewired the loom that was melted together lol), still wouldn't start, so we checked the spark and it wasn't sparking, changed the spark plugs and still no spark, changed the distributor and the coil i think it was and got spark from it, did compression test also was fine and it started but now it wont rev, it just dies when you press the throttle, i really believe this car is cursed haha
Martin
charliecosworth
19-08-2015 02:00 PM
155lee
14-08-2015 11:21 AM
