P8 ecu fault
P8 ecu fault
Hi I've got a escort running with a P8 ecu but when I switch the ignition on the the fuel pump does not prime. I've found that the ecu isn't pulling the fuel pump relay to earth. Is it possible to repair that part of the ecu or has it got to sent away to be repaired
DixieTheKid
14-09-2015 09:04 PM
