Clunky noise from engine on starting and stopping. Ideas???
Hi people!
I'm reasonably new to Fords, with my first and current fling being with a 02 Mondeo TDCi 130BHP.
I'm currently having 2 problems. Having trawled the forum, I'm guesing that the resolution to one of the problems is a new cam shaft sensor. Many contributors suggest this as being the reason why it cuts out from time to time, usually when cold and when clutching in at a junction.
The second problem has arisen over the past week. When starting the engine, it's a much less refined process than before, as in it now fires with what can only be described as a clunky noise. This happens on the moment that the engine fires. And when turning off the engine it also stops with a clunky, rattly noise. Apologies for my non-technical description of this problem but I can't do any better!
Any ideas what the problem might be?
Many thanks in advance.
Brendan
Brendan
If it is the DMF, is it likely to develop into a major problem rapidly or over a long period?
106k on her johnnysash. Not a huge amount by any means.
track.focus'd
12-08-2015 05:53 PM
