how do you tell the difference between a t34 and t34 hybrid turbo
Depends what's hybrid about them, ie if it has a step gap seal or a 360 bearing you will not be able to see, but if a larger turbine housing than std this will show.
People are using the term hybrid turbo so wrong. If you take half of a T3 turbo and the other half of a T4 turbo to creaet a T34, then it is a hybrid turbo by default, always.
Matt Baxter
16-09-2015 08:30 PM
wheelwizardrefurbs
04-08-2015 06:23 PM
differeence, difference, hybrid, normal, regular, sale, t34, turbine, turbo, turbocharger, turbos, turno
