PassionFord
Go Back   PassionFord > Tuning, FAQ & Post Archive's. > Technical help Q & A
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 02-10-2009, 09:55 PM   #1
Xrcossie
Trader Score: (0)
Xrcossie is on a distinguished road
Default Misfire on boost
Hi there,
This is my first cosworth powered car and i'm having a few minor issues.
My car is an XR4x4 with a Escort cosworth 4x4 transplanted into it,
I rebuilt it earlier this year after it spun a big end shell whilst on a dyno being tuned.
Anyway my question is as follows:-
When i am on boost it occasionally misfires like it coughs but it isn't constant and it doesn't do it all the time either What would be the remedy? Will runing a bigger sparkplug gap help if so what size should it be?
I'm runnig after market fully mappable ecu, Coil pack, 440cc flow injectors, mongoose exhaust, rs500 70mm core intercooler, T34 hibrid, pipecross cone filter, Bailey oil breather, ARP stud & nut kit, WRC multi layered head gasket, I'm running 19psi with 22psi peak with 320bhp @ 6700rpm & 300lbs torque @4200rpm.
Once i can get this sorted i want to get more power from the engine, What is the most it can be pushed with being reliable. on my current mods?
Many thanks,
Simon
Xrcossie is offline   Reply With Quote
Old 02-10-2009, 10:04 PM   #2
cossie4i_
TT T38 Power
Trader Score: (11)
cossie4i_ is an unknown quantity at this point
Send a message via MSN to cossie4i_
You need a smaller plug gap to stop misfires
Steve
__________________
TT T38, AB07 Cam, Ported Head, Hart Inlet, Spec-R intercooler, Air Injectors, Gripper Diff , Turbosystems Mapped.
cossie4i_ is offline   Reply With Quote
Old 03-10-2009, 03:23 AM   #3
avid-fan
Trader Score: (3)
avid-fan is an unknown quantity at this point
Quote:
Originally Posted by Xrcossie View Post
Hi there,
Many thanks,
Simon
How much petrol in your tank when it coughs
swirl pot issue maybe ..
__________________
I'm Only Happy When It Rains
PC Bang tidy this link
http://www.hiren.info/pages/bootcd
http://www.frost.co.uk/automotive-bodywork.html
avid-fan is offline   Reply With Quote
Old 03-10-2009, 04:52 AM   #4
bernardd9
Trader Score: (0)
bernardd9 is on a distinguished road
hey i had the same problem wit my old one so i looked into this ford said not to use motorcraft plugs the give me the name but i cant remember it now and i needed to change the ackueater ( not sure if thats spelt right but you should know wat it means ) anyway i had to get a D3 one for it and that sloved all my problems
hope it helps
__________________
ford
built when henry had balls
bernardd9 is offline   Reply With Quote
Old 03-10-2009, 12:16 PM   #5
Trader Score: (0)
tabetha will become famous soon enough
Changing the plug gap will only cure it if that is the problem, which it doesn't sound like.
The best thing you can do is get it fully mapped as it has a mappable ecu, as when it misfires it will give clues as to what's causing it, as emissions are watched.
Could a plug breaking down, could be a dodgy connection, maybe a injector overheating, could be lots, check the usual suspects, cps/connector, phase sesnor, check gaps for both, set plugs to around 0.9mm, I use IK27 plugs, as found the IK31 too cold running.
What are the emissions ?
tabetha is offline   Reply With Quote
Old 04-10-2009, 09:35 PM   #6
Xrcossie
Trader Score: (0)
When it does misfire it doesn't matter how much fuel in the tank,
It miss a couple of times yesterday with 3/4 tank, but today not a thing.
And i pushed it over the speed a few times on my way home tonight.
If there was a fault with the cps wouldn't it play more oftern?
On boost the afr gauge is about 12-13.
I am running standard plugs will invest in a new set, But will need help with which are best for me please,
Thank for your help
Simon
Old 06-10-2009, 10:17 AM   #7
mtommi
Trader Score: (1)
mtommi is on a distinguished road
did you notice if it is worse when it is wet outside. I find that with mine.
mtommi is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Misfire during boost Pri007 Technical help Q & A 3 13-09-2007 04:49 PM
misfire on boost LEE-RS Ford Escort RS Turbo 4 06-09-2006 04:00 PM
causes of misfire on boost help ? sideways500 General Car Related Discussion. 13 14-01-2006 07:59 AM
misfire under boost. mxquattro Ford Escort RS Cosworth 10 09-01-2006 05:42 PM
Off boost misfire? SPADGE General Car Related Discussion. 12 04-07-2005 04:21 PM
