quick way of changing driveshaft boot
is there a quick way of changing a inner driveshaft boot on the front of an escos or do i have to strip the whole thing down ??
buy a sticky boot, one that is split so you can place it over the cv joint and glue it together.(total and utter crap imho and not worth a w@nk) so don't bother.
buy a stretchy boot and cv cone to stretch the boot over. partial strip down
buy a normal boot and strip down completely.
cheeRS nick
I need to change the outer rubber boot of passenger side (LHD) driveshaft in 4wd Sierra Cosworth, do I need to take out the whole driveshaft? Or is there way to strip down part of the driveshaft while it still being connected to front diff so I can install the original rubber boot?
The strip down is quick n simple plus you can check everything over.
chris m1
07-09-2015 08:02 PM
Adam Graham
06-09-2015 06:04 AM
