>>>Last few parts from my dead Cossie, please make any offer<<<<
Old 29-03-2009, 09:15 PM
Si B
2Evos & 1 Escort Van :-)
Si B's Avatar
Default >>>Last few parts from my dead Cossie, please make any offer<<<<
11 th December 2010 - Last of my old Cossie stuff, please take a nosey through and make me a sensible offer on anything you see below
IF NOT LISTED IN WRITING I DON’T HAVE IT ANYMORE SORRY, SOME PICS SHOW SOLD ITEMS NEXT TO ITEMS THAT ARE LEFT
As well as the items below I have a 4x4 Cossie propshaft in the shed, make me an offer!
4x4 Gearbox mount £5
3 * Left hand clear side repeaters with springs. Not cracked. £5 each
Motorcraft coolant cap £4 posted
Pair of Flint Grey electrically heated and adjustable mirrors from my Saph £40
9 * Flywheel bolts £5
4*4 Dizzy cap £5
Saph bonnet vent shield thing £5
Oil pump drive pulley £10 (ONLY THIS ITEM LEFT - it's the pulley on the very left of this pic)
Oil sensor £10
4*4 Through sump driveshaft £20
Ported / flowed / fettled by Cylinder Head Developments Inlet manifold, powder coated silver. Inlet tract no 1 cracked when I hung the inlet on the car with no support for a while, this has since been welded up. £20
New in box Motaquip VCVU800 front inner CV gaiter, 105mm long, 65 & 25mm ends £10 DELIVERED
Delphi Borg & Beck HD5526 Clutch release bearing £20
Cosworth parking sign, brand new £15
ETB Oil temp, Tim oil £5 each RACETECH SOLD
Gear knob, grub screw fitting, left hand side one in the pic only £5 MOMO one on the right has now SOLD
Unused steering wheel boss kit for Mk3 Fiesta Mk5 Escort £20 This may have sold, need to check!
Dizzy caps, 3 * 2wd ones £5 each
2.5 Escort Cossie map sensor, brand new in bag £50 The one in the bag, not the old 3 bar next to it!
Dizzy rotor arms, 1 left £3
Denso Iridium IK31 COSSIE Spark plugs, little use £20
Cossie rocker cover bolt kits, black £2
3 in total x 4*4 Cos Gearbox support cradles (1 comes with a bush) £15 each
Cometic exhaust manifold gaskets, 3000 miles old £5
Cos rear diff hanger, 18 years old I bet, worked fine though £10
4*4 Cos ABS ECU £15
YB standard cam belt pulleys, ideal for refurbing / powder coating £10
3* Cosworth Racing 7.2:1 Pistons and rings, with valve cutouts for BD14s, standard bore 90.8mm £100
8* Valve springs, caps and collets £20 the lot
4wd Brake reservoir cover £40 1 only
Larger items
4*4 Cross member £30
4*4 Saph rear left light cluster, including bulbs, some small marks £10
Saph 4*4 Front ARB with Deflex bushes (silver powder coated, scratched) £30
Stainless steel bonnet stay (this is 10mm longer than standard, and will need the hole on the slam panel filing open a little to fit when shut) £10 CAN BE SEEN IN THE ABOVE PIC ^^^^
Si
Old 29-01-2010, 06:25 AM
Si B
Si B's Avatar
Originally Posted by fezzajsy
mate i will have the ''some random part £5'' cheeRS
paypal payment as gift?
Checked the shed and deffo have it. Will lob in 1st class post on Sat if you want it.
sib666@hotmail.com
As a gift would be great
PM me your full name and address.
Originally Posted by SelbyRST
can you do the rh mirror glass for a tennor posted? Not sure if the prices inc postage or not. To Nottingham and can sort paypal out tomorrow, thanks tom.
Yep, got that out of the shed and into a jiffy bag, same Paypal info as above please
Old 29-01-2010, 04:02 PM
fezzajsy
fezzajsy's Avatar
all done matey
Old 31-01-2010, 09:05 AM
WongRS
WongRS's Avatar
Can i take that off you please?
Old 31-01-2010, 09:26 AM
Matt Baxter
Back in black!
Matt Baxter's Avatar
what are bores like on the block and does it have all the caps with it ? and i take it there are no cracks etc
Old 31-01-2010, 07:43 PM
Si B
Si B's Avatar
Yes matey, be a pleasure for a repeat customer
Paypal as a gift please - sib666@hotmail.com
Send me a PM with your full name and delivery address and I'll get it off in the post either Mon or Tues.
Hi Matt,
Caps are with it. All bores looked fine until I looked closer in no 3. There's a suspect mark. Can't feel or tell if it's a crack, so will have to get a specialist to look at it. Wouldn't feel right sending it to you if it is buggered. Oddly, 6 or 7 years ago when it was in my car, it was running 371 bhp on a T34 .63 absolutely fine Hmm.
I'll try and get it checked this week and let you know what I find out.
Si
Old 31-01-2010, 09:00 PM
Matt Baxter
Back in black!
Originally Posted by Si B
Hi Matt,
Si
Cheers Si
If its all good would you be able to take it to central day?
Old 01-02-2010, 07:19 AM
WongRS
WongRS's Avatar
payment sent
Old 01-02-2010, 09:15 PM
Si B
Si B's Avatar
Cheers Si
Yep no problem Matt, same with any of the stuff on here. Took some of it to Central Day last year too. Saves on postage
payment sent
Got it, thanking you ta! Will be in the post first class to you tomorrow.
Cheers Dan
More positive feedback on it's way to you.
Si
Old 01-02-2010, 09:18 PM
WongRS
WongRS's Avatar
Thanking you kindly
Now just go find me some 362mm AP 6 pots for a 4x4 in your garage? lol
Old 01-02-2010, 09:36 PM
Si B
Si B's Avatar
Thanking you kindly
Your wish is my command:
By 4x4, you did mean Evo fitment right? No, oh well, guess I'll keep them on my car then
Fantastic brakes, thoroughly recommend them. Spend the extra and enjoy well proven set up. I'd recommend Carbotech pads in them rather than DS2500 / DS3000 type offerings though.
Old 01-02-2010, 09:46 PM
WongRS
WongRS's Avatar
cool ! i need to find some reasonably priced 2nd hand ones, realy cant afford new ones, but i do want them lots and lots!
Old 03-02-2010, 04:59 PM
WongRS
WongRS's Avatar
Received today, top stuff! cheers Si.
Old 04-02-2010, 07:14 PM
Si B
Si B's Avatar
Good stuff, thanks for the positive feedback
BTTT for the rest of it. I'm off to Canada tomorrow for a week, so will reply if and when I can get online.
Happy to bring stuff to Central Day if it helps, will need payment first to secure the item though.
Old 04-02-2010, 08:10 PM
Matt Baxter
Back in black!
Any joy getting the block checked Si?
Old 04-02-2010, 08:30 PM
Chip
*** Sierra RS Custard ***
Chip's Avatar
Wong, I can do you those brakes he just showed you for 200 quid
Old 04-02-2010, 09:57 PM
WongRS
WongRS's Avatar
Deal chip
I'll throw a happy meal your way if you make it by the weekend!
Old 05-02-2010, 05:02 PM
Si B
Si B's Avatar
Sorry Matt no joy. I don't want to sell it if it is buggered, and the nearest engine machining place now seems to be Bridgewater, 30 miles from me. I work during the day so not been able to get over to the place.
I'll try and sort when I get back if you can wait, but I'm shooting off right now for foreign lands so it would have to be after 15th Feb.
Oi! Car's going with me to the airport, we're staying with friends near by so you'll have to search around the Heathrow area!
Deal chip
Happy Meal? You know how to win him over then
Old 05-02-2010, 05:17 PM
Matt Baxter
Back in black!
Yeah thats fine Si there no rush tbh as i onky want it for a spare so any time before central day
have a goodun
Matt
Old 05-02-2010, 07:18 PM
Chip
Chip's Avatar
I can easily bring that up for you anytime as well matt, as I go past both your houses at least once a week in an estate car or van.
Old 06-02-2010, 08:58 AM
Matt Baxter
Back in black!
Cheers for the offer
Old 06-02-2010, 10:44 AM
Its Dave
Its Dave's Avatar
I will have them for £200 cheers
Old 26-02-2010, 06:06 PM
Si B
Si B's Avatar
Bargain, I'll even swap them onto your car for you
Bump for everything left in the pics and description above
Old 28-02-2010, 09:24 AM
Some nice bits there fella.I take it you used to have a saff a long time ago lol.
Old 28-02-2010, 10:08 AM
Si B
Si B's Avatar
Thanks Glen, yep used to have a nippy Saph Cos 4*4 with 475 bhp. Was tatty but had some nice bits on it. Breaking it has got me back around £8k ish, which is a lot more than it was worth hole when it was running.
Couple of piccies of it:
It's normal location
Dead gearbox at Castle Combe while taking an extremely fit girl for a run
Smoked a bit too , the oil breather kit return pipe had melted and so oil flowed onto the exhaust:
The reason I got an Evo - this one left me for dead while not smoking the place out
5 years of blood sweat and tears, plus a few ££s. Top fun and met some top people. Sadly 20 year old car, lunatic driver and track days on a budget took their toll
One last pic, my best ever lap of Combe in my Cossie - 1 complete lap following Martin in his version 2 Escort when he only ran around 550 bhp, not a huge amount in it
Was right up behind him till that point on the track when a valve decided to snap, drop down the bore of no 4 and chew up my 200 block, heavily modded head and Cosworth Racing piston
Hence this thread. I blame Martin!
Old 02-03-2010, 05:48 PM
doRSet lee b
doRSet lee b's Avatar
pm'd regarding cam belt cover
Old 06-03-2010, 09:26 AM
Si B
Si B's Avatar
Back to the top, need this crap out of my garage!!
Old 10-03-2010, 09:22 PM
Si B
Si B's Avatar
Up again!
Old 15-03-2010, 04:30 PM
cossiedoc
cossiedoc's Avatar
have you still got the 4x4 hubs in pic mate if so how much cheers steve
Old 20-03-2010, 09:12 AM
Si B
Si B's Avatar
No sorry, I've only got the parts listed with a price. Everything else has gone.
Si
Old 20-03-2010, 10:23 AM
Joe Grp4 Escort
Joe Grp4 Escort's Avatar
pm'd
Old 02-04-2010, 04:01 PM
Si B
Si B's Avatar
Back to the top
Old 02-04-2010, 07:19 PM
neil andeRSon
neil andeRSon's Avatar
have you still got the rhs mirror glass mate??
Old 02-04-2010, 07:57 PM
Si B
Si B's Avatar
Yep, although the box its in doesn't look so healthy as it got wet once digging it out for photos.
Si
Old 02-04-2010, 08:18 PM
neil andeRSon
Si
long as the glass is ok it don't matter bout the box. how do you want paying? is your price inc p+p?
Old 02-04-2010, 10:21 PM
Si B
Si B's Avatar
Call it £11 and I'll post it out to you. Paypal address:
sib666@hotmail.com
Send as a gift please, and PM me with your full name and delivery address
Old 03-04-2010, 04:42 PM
neil andeRSon
sib666@hotmail.com
done..
Old 04-04-2010, 06:35 PM
Si B
Si B's Avatar
Got it, thanks
Will post out on Tues when the PO reopens
Old 04-04-2010, 09:16 PM
fostersice
fostersice's Avatar
looking for a turbo heat shield for a 4x4
Old 05-04-2010, 11:20 PM
Si B
Si B's Avatar
Sorry fella, I've only got the items listed above now
Quick Reply: >>>Last few parts from my dead Cossie, please make any offer<<<<
