Zzz...Zzz sleeper granada
#241
cool,
#244
A small update of the rear suspension build.... =)
Machining "bearing-tubes" for the boomrang arms :
They turned out like this :
Bomerang arms , made from T6alu.. :
Test fitted :
Almost ready for for the tig :
Just the welding left now...
Next update will have engine pictures----stay tuned
Test fitted :
#253
ENGINE!!
Okay , as promised I would post some engine pictures by the end of the week... here they are...
Inlet manifold colour and coil pack placement is not decided upon yet as you can see...
Front drive accesories,belt drive fuel pump and wastegates is not present on theese photos - i know , I haven't forgot about them..!
Have to say we are really pleased with the aura of theese 227kg's of PURE THRUST.....
4 plate carbon/carbon clutch on T6 billet flyweel
Large throttle body, and 1680ccm injectors hooked on to the rails..
one more with more light
What do you think??
Joel
What do you think??
Joel
#265
That's not my intention - to tease you ! :P
Mhmmm, I really don't want to neither think or talk about the cost of this... examples are just the clutch for instance, wich was £3000(sponsored price) you know, and buildig the exhaust manifolds was about £2400 just in materials... :S
No, not 2k hp.
The engine can produce well over 2000hp,(it wll give about 2300hp at 2.4bar boost) but turbos is its only limitation , they can produce 1750hp at the maximum in teory , so we'll se how well they hang in there.
It even passes 1000hp before 1 bar(14.7psi) of boost.
If we get 1500,1700 or 2000hp really doesent matter, it is only in it's drag-spec configuration it will be ble to put down these hp numbers.
As it is now it produces 170hp at idle, 290hp at 2000rpm... and after that the turbos really kick in... so there is always enough power...!
Totally off bost, it produces somwhere between 550-600hp if everything continues as planned...:P
#271
fpmsl @ 550 / 600 hp OFF boost fair fucking play AWESOME
I tell you what i would love to see this over here and i recon so would everyone else on this forum' I would donate some cash to get you over here Joel ( not a lot but it all counts lol ) and i bet ALOT of others would too
#273
objects in my mirrors will soon dissapear!
fuckin hell mate , half the planet is going to dissapear in those turbos
what an truly amazing build!
p.s if you bring it over here for totb , charge people £35 a ride down the drag strip , you'll be a multi millionaire after only one day. ive got my £35 ready
cheers paul
cheers paul
#280
cheers paul
cheers paul
Sounds like a really good idea, IF, anyone want to go with me after seeing me drive... :P
