FITTING FOCUS RS CALIPERS AND DISCS TO A MK5 ESCORT
HELLO PEOPLE
I WANT TO FIT FOCUS RS CALIPERS AND DISCS TO MY L -reg MK5 ESCORT 1.8 16v ZETEC SI
I HAVE 17"s ON IT, IS IT A QUESTION OF DRILLING OUT THE HUBS LIKE YOU DO WITH THE ST170s AND THEY WILL FIT STRIAGHT ON OR IS THERE MORE INVOLVED??
WILL THEY EVEN FIT OVER 17"s??
Help Help Help
Help Help Help
You need conversion brackets from ZOO MOTORTSPORT £80 and 17inch COMPOMOTIVES to clear the calipers or 15mm hubcentric spacers.
Simalar set up on my M4 ESCORT.
Some pic of my FOCUS RS calpiers painted red.
so would the wheels stick out and look abit silly with the spacers on the wheels??
was going to use these wheels
the spokes bulge out abit more than normal wheels, do you think i might get away with it??
why won't my pic come up then?? Hey GRACELAND i always start my topics on caps lock so people can see my question more clearly in the first place and not get confused
Team HOTHOT!
With regards to wheels sticking out - get the right offset, your car will handle better, tramline less and your wheel bearings will love you forever more!
Didn't stick out that far.Still was in legal limit.
As for the conversion brackets,there's some one on here that does them,think there from essex.TWINS off here uses them.
COMPOMOTIVES seem to be the only wheel that clears the FOCUS RS caliper without the need for spacers.
I was too tight to shell out £900 for a set.
sorry for all the questions but do you think the spacing would be different on a mk5 escort hub??
like not needing such a big one etc..
Just need to fit the calipers and try the wheel on.Then measure and see what size spacer you need.
Calipers and discs are not cheap though.Got mine off E-BAY. for £200
Thanks MERCURY GREY MINTER. will have to do that then, i just thought Focus rs brakes would be alot cheaper than Hi-spec. i'm happy with spending a couple of hundred.
Deffo got to be E-BAY.
GOODLUCK.
jason_nike
18-08-2019 10:53 AM
