focus road/hillclimb
suggestions please
i have a focus, was a zetec 1.6 originally, i bought it with a ST170 motor fitted, on Suzuki GSXR1000 throttlebodies and Hyabusa injectors, i would like to change motor to a 2.0ltr Duratec, cost permitting, any suggestions, would it be easy enough?
Ben
Duratec is far superior than a glorified Zetec.
What year is the Focus?
I disagree, the duratec is a good engine and can make good power with the right mods, but an st170 engine is virtually bullet proof, forged rods and a big valve head etc as standard. You can chuck about 400 bhp through a standard bottom end and head gasket. Think the biggest weak spot is the oil pumps which just don't take lots of revs.
Ben
I guess it depends on whether we're talking turbo or N/A, as a Duratec will put bigger numbers down N/A.
It'll be custom parts getting it mounted then I think, not sure what box they'll bolt up to either as they aren't your usual Ford bolt pattern.
There is only mk1 focus I know of in Europe that has a duratec in and that's only part way through the conversion, and that's the AJ Racing time attack ST170, we are using a mondeo 2.0 mtx-75 gearbox, to mount the engine you either need the north American focus duratec engine mounts or custom jobs, not sure on drive shafts, and we have a custom bearing carrier on the rear of the engine for the driveshafts.
wowk
30-03-2021 07:49 PM
