More bits for project ' Queen '.
Old 03-11-2013, 02:35 PM
  #41
capri-rs
capri-rs's Avatar
drysump Rod......cant see the pics
Crazy project anyway,good luck
capri-rs is offline
Old 03-11-2013, 03:11 PM
  #42
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Still in its box i expect ive not really seen it either. The sump has already been sent out to be machined to Marks Spec thats all im aware of. Ive not seen Pistons, Rods or Crank either but ive payed for them so assume they exist . Mark is 40 miles away so I dont visit often it takes too much time out of my retirement schedule, how did i ever get time to work, beats me .
Rod-Tarry is offline
Old 03-11-2013, 04:20 PM
  #43
Paul_RS
Paul_RS's Avatar
Originally Posted by Rod-Tarry
Are technical achievements fun not at the time thats for sure.
Putting a 25k engine on the line is not fun either & few do it.
27 runs todate 2 ended in failure & they deffo were not fun .
I can imagine
I would just be nice to see the car do it's stuff (easy for me to say as I'm not paying for any of it lol )
Paul_RS is offline
Old 03-11-2013, 06:48 PM
  #44
gingerturbo
The annoying ginger guy
gingerturbo's Avatar
I can just picture what your schedule use to be like when you was hard earning if you struggle to have time nowadays
gingerturbo is offline
Old 04-11-2013, 07:14 AM
  #45
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
I think the problem is you simply cant cope with as much as you get older. You slow up cant imagine getting up at 6.30 for the daily comute I would be dead in a week . Its clock into the coffee shop at 9am these days for an hour reading the papers then drift slowly into what needs doing.
Old 04-11-2013, 05:55 PM
  #46
costina
Live long and prosper!!
costina's Avatar
Rodders that sounds like bliss enjoy it as I doubt most of will be in that position
Regards
Paul
costina is offline
Old 05-11-2013, 05:46 PM
  #47
carl/saff
SIERRA RS 4X4 COSWORTH
carl/saff's Avatar
Goodluck Rod
carl/saff is offline
Old 06-11-2013, 09:05 AM
  #48
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Not much happening because Mark is at Sema but a package did arrive today from Jenvey. Distribution Block with all pipework to run idle control & ECU etc.
Old 22-11-2013, 06:38 PM
  #49
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
All the bits for the new engine will be ready to go to Vibration Free next week. Discussed what we are trying to achieve with Mark the Maths say if Torgue is limited to 660ft-lb across the range it will require circa 58psi (4 bar) of boost to make 1000bhp @ 8k we will try to push the GTX42 & the EFR9180 hard enough to see if in practise those figures hold true. The fuel will be E85. The aim is also 800bhp on pump fuel for the road which will require more sensible boost (2.8 bar).
It now looks as if the 1000bhp engine may be used in the car & not just for show bit mind blowing for an old geezer but im as mad as a box of frogs so lets bring it on. The Nitrous will then be for show not go.
One problem is the Autronic internal map sensor only works to 50psi so we are asking if they can fit a 5bar absolute if not Mark can map around the limitation for a Topspeed run. The real solution is the new fancy ECU ive had my ears bombarded with but that means a new loom, sensors etc for maybe a single Topspeed run.
Having been told whats comming from the EFR range in 2015 I may as well chuck this lot in the bin it will change the game again. They will also look at one of Marks suggestions for 2015 guess what it will be perfect for mine the barsteward I wish to quit in 2015 .
Old 22-11-2013, 06:52 PM
  #50
gingerturbo
Lol all fun and games
4bar of boost will be enough to rattle anyone's bones
Old 22-11-2013, 06:54 PM
  #51
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
Pushing the boundaries rod! It's what your car has always done which means the rest of us can also use the up grades that work for you
ajamesc is offline
Old 22-11-2013, 07:07 PM
  #52
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Heard about your new engine today Andy with the bigboys with that Spec. Should pull mid 190's on race fuel & i will pester you untill you give that a bash .
Old 22-11-2013, 07:11 PM
  #53
lee2cossies
lee2cossies's Avatar
Rod you are definetly mad! 1000hp is going to be epic I've been hoping u would go for 1000hp all along, great news and good luck I'm sure it's going to be incredible when finished!
How did u get on with that book you were going to do on your car?
lee2cossies is offline
Old 22-11-2013, 07:15 PM
  #54
ajamesc
ajamesc's Avatar
Yeah I'll take it as far as I can on a standard crank mark has my head at the mo I meant to pop there this week to pay for that and order some rods and pistons will start taking shape a few months into 2014
ajamesc is offline
Old 22-11-2013, 07:25 PM
  #55
opposite lock
opposite lock's Avatar
Epic levels from the MAD crew Im just trying to get my head around 3 bar plus
opposite lock is offline
Old 22-11-2013, 07:26 PM
  #56
Sonic Boom
Sonic Boom's Avatar
Whats the 2015 EFR range going to be like?
Will they still use them same twin scroll manifolds that are on the current range?
Rich
Sonic Boom is offline
Old 22-11-2013, 07:34 PM
  #57
Mark Shead
Mark Shead's Avatar
Rich
I cant say what the changes are as it was top secret, I was lucky enough to visit the back room on the BW stand at Sema with the designer and two other high end dealers and give our views on the new stuff coming and what we wanted,
The manifolds will stay the same.
Mark
Mark Shead is offline
Old 22-11-2013, 09:19 PM
  #58
Sonic Boom
Sonic Boom's Avatar
Mark
I've just got enough money together for a manifold and I bought a Tial 44mm wastegate a couple of months ago so was going to buy the bits in stages for an EFR setup.
But I might just wait a year for the 2015 EFR turbo now.
Rich
Old 22-11-2013, 09:53 PM
  #59
lee2cossies
Same here was just about to start buying the bits but think il wait a bit too. Good news tho.
Old 22-11-2013, 10:36 PM
  #60
botters
competant bodger
botters's Avatar
rod as arsey as some of your comments can be towards other peoples cars and what is and what isnt fast (and my replies to you also) i must say i have to thank you and the mad crew for pushing the boundaries and moving the cosworth tuning scene forward. i guess without the work you guys do we would all still be lagging round on t4's with claimed 500 horses
botters is offline
Old 22-11-2013, 10:50 PM
  #61
lee2cossies
Botters, well said I agree with you totally. You really are pushing the boundaries who would have thought back in the early 90's when 500hp in a Cossie was big power, now in 2013 there are yb's with double that!
Old 23-11-2013, 07:39 AM
  #62
Mark Shead
Mark Shead's Avatar
Rich
No point in waiting for it as we are not sure what version will be ready first and we were asking for the really big ones first.
Mark
Old 23-11-2013, 07:40 AM
  #63
Mark Shead
Mark Shead's Avatar
We were talking about this yesterday about 15 years ago I would have said 600hp was the max lol.
Mark
Old 23-11-2013, 09:03 AM
  #64
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Mark
Mark
Reminder to measure those pistons .
Old 23-11-2013, 11:55 AM
  #65
Sonic Boom
Sonic Boom's Avatar
Mark
How much of a leap forward are we talking over the current EFR?
Rich
Old 13-12-2013, 03:36 PM
  #66
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Had an horrendous 2 weeks with my teeth problems so didnt even think about the car .
Saw Mark today the new I/cam has arrived. Mark said the CP Pistons we have are not suitable so a new set has been ordered from the States. Its a 1off so will take time, its due last week in January. All other parts are now available except the valve springs which are still to be specced so all the bits will be off to VF for balancing next week.
The ECU can be modified to take a 5bar absolute map sensor so that up to 60psi can be used BUT it will take about 3 months or more as it has to go back to Australia . Mark can map around this so we are going to leave the Map Sensor as it is. If we decide to run these silly Boost levels in the car the ECU can be modified after the Dyno session.
Old 13-12-2013, 05:39 PM
  #67
opposite lock
Health comes first always Rod I hope things are improving.
Old 13-12-2013, 09:11 PM
  #68
I hope your teeth are sorted Rodney.
Glenn_ is offline
Old 14-12-2013, 08:46 AM
  #69
Fil
ELASTIC BAND
Fil's Avatar
teeth and 1000bhp cosworths in the same thread
1st hope the teeth issues get sorted!
and at the spec 50psi sounds interesting and I net a slow gera change should provide some highly amusing wastegate chattering noises.
but where would you find a suitable dumpvalve to handle that sort of psi
can wait to see / hear what it runs at
Fil is offline
Old 14-12-2013, 05:52 PM
  #70
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Not completely. Ive 4 new ones fitted so far one more implant after Crimbo. The gums needed umpteen stiches because of the infection.
When the last one is fitted the rest will be whitened to match up .
Lots of photo's taken so the dentists can use them on her website to show what a shite state your teeth can get in & how they can be sorted .
Old 14-12-2013, 05:54 PM
  #71
ajamesc
ajamesc's Avatar
I bet that's almost costing as much as your engine rod!
ajamesc is offline
Old 14-12-2013, 09:09 PM
  #72
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Not as much as that but more than i want to spend on my looks at my time of life .
Old 16-12-2013, 04:17 PM
  #73
CrOwSoN15
Ben
CrOwSoN15's Avatar
I don't think any amount of money can help those looks Rod
CrOwSoN15 is offline
Old 16-12-2013, 05:19 PM
  #74
Chip
*** Sierra RS Custard ***
Chip's Avatar
Nothing happens for months & then it all happens at once .
The part we are having made to help with Block integrity is complete & ive just payed for it . Cost a tad more than discussed but its a first for a YB & was a tad more difficult to develop. Will be taking all the bits to the Vibration people to get balanced as a unit after Mark gets back from Sema. Think Mark has other idea as well that will be discussed at the time. We are giving this a good shot lads it wont be easy.
Ive always stopped Mark going for big Power cos I needed to drive this thing to the Darby & Jones club but having two Spec's will i hope give the Tall one a crack at some big numbers. If it fails thats life but if we dont try I think I will always regret it in later years as I consider mods to my my zimmer to make it handle better .
Cracking attitude Rod, cant wait to see it
Chip is offline
Old 16-12-2013, 07:01 PM
  #75
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Want you as the idependant viewer at the Dyno if thats OK mate. Long time no see .
Old 17-12-2013, 10:37 AM
  #76
WTF?!
WTF?!'s Avatar
Awesome stuff.
I really can't imagine your current YB record being broken by anyone but yourself, not because it's not possible, but due to to the age of them and the massive amount of money and effort put in, not many people are willing to go to the efforts that you are.
Obv' using other engines it's possible (Hell, there's an Evo that's done 237mph in the standing mile coming up to 4 years bck now), but for YB engine Fords, I reckon you have it in the bag for ever.
Mark
Even 13 years ago I remember Rainbum adamant that 'RS500 spec' was the ultimate and nothing else was really possible, then a few years down the line he'd seen what was going on in Scandinavia and had changed his tune to 'anything beyond RS500 spec is like a grenade with the pin pulled out'.
Funnily enough, he doesn't say that anymore lol.
WTF?! is offline
Old 17-12-2013, 06:08 PM
  #77
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Originally Posted by WTF?!
Awesome stuff.
What you dont know is why im still having a crack at these things. In January 2004 I set out a series of objectives for my car.
1. Beat the Sierra RWD record of 191.6mph
2. Beat the overall record of 194.6mph
3. Try to exceed 200mph
4. Hold/Defend that record for 10 years.
Well its 9 years 3 months yesterday so getting there .
Old 17-12-2013, 06:12 PM
  #78
ajamesc
ajamesc's Avatar
Everyone needs an exciting hobby rod if money allows then fair play! After all we are only here once
ajamesc is offline
Old 17-12-2013, 07:46 PM
  #79
Paul_RS
Paul_RS's Avatar
Glad you got them sorted
However they should really whiten your teeth first and match the implants to them. That's a much better way of doing things.
Paul_RS is offline
Old 20-12-2013, 04:21 PM
  #80
Rod-Tarry
Happily retired
Rod-Tarry's Avatar
Last minute Panic .
Was going to take my parts to Vibration Free today so at least they were delivered before Christmas.
Mark gathered all the parts together but could not find the Clutch just an empty box. He rang & I thought i had it somewhere in the house but searched to no avail.
I then sort of remembered taking it to VF some time back before all the change of Specs etc. I rang but the young lady who was alone manning the phones knew nothing but took my details.
I now asssumed it was lost much like my flywheel on the last re-build (My cleaner threw it out when she found this hunk of old metal in the lounge behind a hi-fi speaker ) & I was taking the usual pensioner jibes from Mark about my memory .
Got on to the supplier to order a new one but for some unknown reason i didnt place an order but said i would wait till after Chrimbo.
This afternoon received a call from VF the young lady had found my last order & it stated I had left my clutch with them. This wonderfull young lady then search there stores & found a Clutch in a sealed bag in the " WTF section " Yep! it was mine.
I could still get it there before Christmas if i take it on Tuesday but I probably wont bother now.
Quick Reply: More bits for project ' Queen '.
