2.5 focus rs to cossie t5
Hi I am in the process of putting a focus rs engine in my sierra with a t5 cossie box does anyone no anyone who could make me some engine mounys modify the sump and the main thing make a spacer plate to mate the cossie t5 box to the rs engine using a 960 volvo auto bellhousing thanks
Thats what I will do or I will use mk motorsport if I sm stuck could probably make mounts and sump my self just not sure if I have the knowledge to do bell housing lol
Well already got engine once fitted will be coming back out to go to jamsport for a bit tweeking and got my box and bellhousing just need to get adapter plate machined up and work out for me engine mounts and sump modified then can get it bolted in with some aftermarket management then can start getting it some were alot of work but will be worth it in the end hoping to have it done for croft lol
It is by far better to get hold of an fwd gerbox for the volvo lump and cut the bellhousing and weld it to the RWD gearbox. Even if you break the T5 you can swap the bellhousings.
Make your adaptor template
Then get it cast
Then machined
It shouldn't cost more then Ł250 if your wise about it
And remember if you make a pattern , add 1% for shrinkages
Then get it cast
Then machined
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
