escort 1.8 zetec turbo. Do i need lamda sensor
im in the process of building my escort 1.8 escort zetec turbo, basicly the spec is erst turbo t3 and manifold, decompression plate, 2 st170 head gaskets, standard inlet ( got to get frst rail and injectors ) OFAB ecu and loom, my question s amongst others is do I need to put lamda in the down pipe if so can I re use the escort 1.8 one
ye you are right mate, I only know this as me dad had mk5 rs2000 and got a de-cat fitted with his stainless and mot's said it was fine, I was going to get some sort of cat fitted just for mot,s but abvoisley the question has risen again then would I need a lambda sensor
I wouldn't get away with fitting the ofab set up on the mk4 fiesta would I ?Then what makes me wonder is ive seen ka turbos on here with ofab set up lol
Not Crazy, just Unwell
No N/A 2.0. That shouldn't matter. The pre cat emissions are a higher percent carbon rate. Asking as it falls within that band it's fine. Think about every car pre 92 had to go by the same test, 1.0 - 3.0+. So I wouldn't worry bout it too much.
Thank god for that lol thanks mate for your help, im going to try an find the year of the engine if I can, would you no how to find this
There was a way that a car dealer showed me when I setup. It's to do with the little clock looking imprints. I'm sure you will have seen them on a part or 2. To get a rough Idea go on if its a silvertop or blacktop. That will narrow down to pre or post 2000 roughly
Doesn't matter. You could have changed the rocker cover. The blacktop is more likely to be easier on emissions as its slightly newer. Font quote me but in theory the newer and lesser wear should do you a favour
sorry mate, LOL, just read that first bit again after putting "what do you mean" lol makes perfect sense LOL, sorry, having abit of a girl moment there lol, well im hoping it'll be ok as it'll make my life easier to just to get escort rs turbo stainless downpipe and just modifiy it to fit my mk5 rs2000 mongoose that already has de-cat fited to it, stole it off me dad lol not that he cared bless him
Top bloke!! When mines built and I get a little puma to stick it in, ill be making my own stainless exhaust. I'm not too handy with a mig but my dad used to weld manifolds for different race event teams so he can weld shit hot lol. Get a few tips off him.
mines a baby compared to yours, with out sounding a tight sod lol, when I looked into doing this I saw a lot of people saying how cheap they built a budget build, well im sort of on the mission to get it as cheaper than them but as long as its got proper ford items new in same cases coz want it done properly lol, I take it you,l be sending it off to get wired up
Christ your joking lol, im having trouble how to wire up the ofab loom o my 1.8 loom, no one can give me a straight answer lol
