grpa spec / wrc look escort cosworth track car with 700bhp 2.2 harvey gibbs engine
i have been building this car for the past year odd now, i have a thread on www.escortrscosworth.com but thought i would post on here incase some people might be interested in it.
the build is based around a mint 12000 miled cossie shell and full grpa / wrc parts.
i hope yous like.
ruff spec to give an idea.
700hp 2.2lt full race harvey gibbs engine running t6 ect
ffd 7 speed sequential gear box
7.5 inch ffd front diff
9 inch rear diff
wrc/ grpa drive shafts
proflex suspenion
wrc front up rights
93 wide track square beam and mag arms / gold toe links ect ect
steel front x member grpa
gold wide track front tcas
comp struts
bladed anti roll bars
wrc brembo brakes 8 pots front and 4 pots rear
grp a brake peddal box
grp n brand new stearing rack with grpa rack and boss ect ect
shell has a full custom danny b cage t45
wrc front suspenion turret top hats
wrc chassi engine mount brackets
rear bladed anti roll bar brackets
shell has
carbon roof
carbon bonnett
carbon bonnett vents
carbon wrc rear spoiler
carbon grill
carbon light covers
carbon tunnell liner
carbon floor linners
carbon door cards
carbon rear qu cards
wrc steel wings
wrc front bumber
flocked dash
digital dash fitted into carbon suround
full rally car loom and fuse pannel
twin head lamps with the inner removed and a air duck fitted
fuel cell
fuel swirl pot
3 pumps system
braded lines through out
harward and scott full custom twin box system twin 2.5inch system with 4.5 inch down pipe
pro alloy 100mm core intercooler
pro alloy rad and pre rad
slim line fans
pro alloy header tank with site glass
pro alloy water and windscreen washer tank
pro alloy power stearing tank
thats all i can think of of the top of my head.
will up load photos soon .
thanks steven
i hope yous like.
9 inch rear diff
proflex suspenion
wrc front up rights
comp struts
shell has
carbon roof
carbon bonnett
carbon grill
carbon light covers
carbon door cards
wrc steel wings
wrc front bumber
flocked dash
fuel cell
fuel swirl pot
3 pumps system
slim line fans
thanks steven
Sounds good mate. does harvey have to take it to a 2.2 to get 700bhp or is it for some other reason ie better to drive with that power. what gets it up to 2.2 rods and pistons and what size does the block get bord to?
be nice to see some pics mate
on the escort cosworth site when i up load a photo its smaller ? on this site its to big how do i cut the photo size?
thanks steven
thanks steven
after talkin to harvey ref his own engine i decide to go 2.2 as it gives me more flb so i have more power on tap faster / lower down the revs.
spec is 2.2lt crank, pistons,rods,linnered block,nick wapples head , harvey gibbs spec cams, harvey gibbs spec inlet, swedish exhaust manifold, harvey gibbs spec turbo , t6 ecu , and all the other little bits and bobs to make it all happen.
should have my new engine next week when harvey home from his jollys
thanks steven
cars built by mc neill motorsport here in ireland
all body work was done by my cusion adie
all engine building ect is done by harvey gibbs ( scs )
thanks steven
thanks steven
Very nice mate. I knew you could get 700bhp from a 2.0 as ive seen it before. The main reason for asking was to see if it was a better engine to build like easyer to make power and more drivable engine to have with that power. With that size engine would it be nicer to drive on the road.
Do you have to change the crank size to get 2.2
thanks
lee
thanks
lee
wrc front bumbers are not easy fitted to have a nice gap around the wing but i think adie my cusion has done a good job.
thanks steven
thanks steven
heres a photo of a std steel wing that gordon vincent as made into a wrc wing , hes a top man at the job .
also you can have a peak at the colour i painted the car who knows the colour? i had a gay bald chap help pick the colour ( hes got a white escort cossie with gold wheels if that helps yous to work out who he is)
thanks steven
thanks steven
i didnt go for a wrc rear end mark as it was a more or less straight fit up with the 93 wide track rear end, where to go wrc cradle the rear turrets need modded ect.
domanic said that a good grpa set up was fine for track days.
how ever on my jwrc fiesta cosworth build i have went for full wrc rear end , all fabb work to the fiesta is all done by gordon vincent, i have not got the shell home yet so dont have any photos at the moment.
thanks steven
i fitted a alloy fuel filler into the quarter pannel , no need to be inside the car trying to fill the fuel cell. its the same colour as the car i no the photo for some reason makes it look a darker colour.
thanks steven
thanks steven
