Ep3 Turbo build (plus some other honda stuff)
Old 06-03-2011, 10:57 AM
RickyLee53
RickyLee53's Avatar
Default Ep3 Turbo build (plus some other honda stuff)
Just started this EP3 turbo build, we are currently waiting for parts (turbo spec was changed).
We are going for around 400hp on the stock engine. The car was around 240hp when it was dropped off with us.
This is the turbo we were going to use but decided to downgrade to something a little smaller.
Intercooler pipes are done as far as we can without turbo.
So is the intercooler. I flow tested this against a vertical core and this gave the best results. (will post pic's when I get them of the PC at work)
I've never seen an intercooler done like this, so remember, you saw it here first
3" exhaust to make next week, while waiting for the turbo etc to turn up, then the manifold etc when it gets here
Old 06-03-2011, 11:09 AM
GribbiN
GribbiN's Avatar
Intercooler pipe work is a work of art, do you do this yourself ?
Old 06-03-2011, 11:19 AM
RickyLee53
RickyLee53's Avatar
Actually not on this build, the lad who works for me did it. I welded up the intercooler itself.
Old 06-03-2011, 11:22 AM
danneth
TORQUE!
danneth's Avatar
as usual, should be interesting when done ! i think i need some pipe work doing from you
Old 06-03-2011, 11:39 AM
crumpet
crumpet's Avatar
do you make manifolds for yb's?
Old 06-03-2011, 06:49 PM
-beefy-
formerly beefy-rst-2
-beefy-'s Avatar
iirc and may be jumping ricky to a reply but the answers yup Ź
you made rooises didnt you ricky ,
will keep an eye on the build mate !
Old 06-03-2011, 06:52 PM
fogulbennett
fogulbennett's Avatar
My mate has a ep3 turbo been dyno'd at 420ish at the wheels and not been mapped yet getting mapped soon cams and some head work should be a monster!!
Will be keeping an eye on this also
Old 06-03-2011, 07:03 PM
Good luck with the build.
Old 06-03-2011, 07:35 PM
RickyLee53
RickyLee53's Avatar
I'm guessing its got a "built" engine, this is going to be a stock engine remember.
Shouldn't need head work or cam's till well above that power though IMO.
Old 06-03-2011, 07:45 PM
fogulbennett
Yea his is forged mate he's going for as much as he can get think he's wanting 5-600 maybe not sure he has money too spend so only time will tell
Old 06-03-2011, 08:38 PM
RickyLee53
RickyLee53's Avatar
Sounds good, This one is just a standard engine, i'd keep the cams and head standard till WELL over 600hp though.
Old 06-03-2011, 09:15 PM
RS Grant
Made in Scotland
RS Grant's Avatar
Interesting build Ricky, I assume it's already running Hondata from the sticker in the bay.. what size of turbo has been chosen now?? Should be pretty lively once it's finished mate!!
Cheers,
Grant
Old 06-03-2011, 09:33 PM
fogulbennett
It's lee's civic mate
Old 06-03-2011, 09:44 PM
RickyLee53
RickyLee53's Avatar
Cheers,
Grant
Turbo is smaller now as the goals have changed. Still a GT30 sized turbo.
Making the 3" custom exhaust for it this week. Its super tight over the rear control arm.
Old 06-03-2011, 09:46 PM
crumpet
crumpet's Avatar
you have much work to do with holsets? like h1e's and hx35s? btw can you weld cast?
Old 06-03-2011, 09:51 PM
RickyLee53
RickyLee53's Avatar
We've used a few, HX35's infact i'm just doing a "budget build" for a customer now using a HX35. They are big, heavy, horrible things, but they make the power and do the job, great for a budget build IMO.
Welding cast isn't a problem, but heat and welding cast can sometimes have issues. I've done various turbo's and manifolds in the past and never had a reported problem. But there a pain in the arse to do at times.
Old 06-03-2011, 09:56 PM
RS Grant
Made in Scotland
RS Grant's Avatar
I know mate, that's why I am laughing...
There is no way on planet earth that car is making a proper 420bhp at the wheels. I'd love to see what the dyno graph that I've heard backs up the claims looks like!! I've seen the thing go remember and it drives like it's got about 275whp, absolute max. So I assume that up to 7000-ish rpm there isn't much while the turbo spools, then he gets the extra 145whp in the final 1200-ish rpm before redline?!
Also, forged or not, rolling around giving the car stress while unmapped is a dangerous game to play.
Cheers,
Grant
Old 06-03-2011, 09:58 PM
RS Grant
Made in Scotland
RS Grant's Avatar
What sort of rear box is the car getting Ricky?? ....I've seen some EP3 Turbos which run an exhaust which goes under the rear arm, bit more like a straight drag exhaust.
What sort of power is the standard K20 bottom end good for in your experience??
Cheers,
Grant
Old 06-03-2011, 10:00 PM
crumpet
crumpet's Avatar
how much are budget builds on average?
Old 07-03-2011, 09:56 PM
RickyLee53
RickyLee53's Avatar
Cheers,
Grant
The car isn't mapped and makes 420whp? The k20 flows masses of air, it'll spool HUGE turbo's really early.
Cheers,
Grant
400hp should be a breeze, there much bigger physically than the b18's and we've done over 400 on stock b18's.
Taking the exhaust under the rear arm isn't practical on a road car IMO.
On the EP3 there a lot more than the b series.
Old 07-03-2011, 10:43 PM
crumpet
crumpet's Avatar
on a b sseries to get 400, b16
Old 07-03-2011, 11:50 PM
RS Grant
Made in Scotland
RS Grant's Avatar
Yea that's what I thought when I heard 420whp without being mapped... and after I saw the thing getting stress and not shifting anywhere near as quickly as a true 420whp car should, I seriously doubt the claim.
Brilliant. ...I'm not sure if you've had any experience or contact with a TTS Rotrex Supercharger equipped EP3/DC5 before Ricky, but if you have, how do you think this Turbo kit compare driveability-wise??
Cheers,
Grant
Old 08-03-2011, 12:01 AM
Chip
*** Sierra RS Custard ***
Chip's Avatar
Lol @ tripling the standard power without being mapped
Old 08-03-2011, 09:17 AM
keithg3334
keithg3334's Avatar
Good work as per usual Ricky!
Things must be going well if you've got someone working for you now.
Old 09-03-2011, 08:17 AM
RickyLee53
RickyLee53's Avatar
Cheers,
Grant
I don't think the comparison is fair to be honest. Turbo is a MILE infront. Not just on this but any car, superchargers are a thing of the past. New manufacturers are going away from superchargers, very few use them now. In a years to come, virtually every new car will come with a turbo. The supercharger on an Ep3 gives a very different style to the engine. The turbo works inline. Spools very early anyway and makes bags of power up top. I'm yet to be impressed by a supercharged Honda to be honest, there ok for lazy V8's or something with a peak VE of about 2500rpm's.
I thought tripple the power was an acheivement when we first did it a couple of years ago, how foolish all the hours i spent mapping it.
Thanks mate, i'm suprised your not back in a turbo car! I've actually got 2 people working full time now.
Anyway back to this car. Exhaust is currently been done, still awaiting the turbo. Will post pic's of the exhaust later.
Old 09-03-2011, 09:16 AM
keithg3334
keithg3334's Avatar
I am, got another Evo 6
I might be tempted to go back to a Teg or Civic turbo tho as the Tein coilovers on the Evo are a bit harsh & my G/F does nothing but moan about it and on the baby's neck.
Did you ever get your EG finished?
Old 09-03-2011, 06:45 PM
RickyLee53
RickyLee53's Avatar
I've got a 6 also, theres something about the fwd honda's that makes you though.
My EG's in a million pieces ready to paint etc, its nearly finished parts wise. Spec is somewhat bigger than before. Its virtually a full carbon body now. Removal alluminium front end, double diffuser. Sleeved b18, GT40 custom spec turbo. Hoping for 700hp and 700kg's.
Old 11-03-2011, 06:50 PM
keithg3334
keithg3334's Avatar
Yeah mate, that the Icelle blue on you had the last time I was down. Never seen a build up of it anywhere tho.
Old 16-03-2011, 11:46 AM
escort1989uk
escort1989uk's Avatar
Any updates
Old 16-03-2011, 11:48 AM
Chip
Chip's Avatar
GET SOME FUCKING PICS UP YOU CUNT!
You can just tease us like that
Sounds awesome!
Old 16-03-2011, 04:50 PM
RickyLee53
RickyLee53's Avatar
Originally Posted by escort1989uk
Any updates
We'r still waiting for parts as we changed the turbo we planned to use. I'm hoping to get the new turbo by next week. The exhaust and a few more bits are all made but no pictures because we took it off the ramp before i took any. Updates next week i'm sure.
Sounds awesome!
Sorry, not yet, body work is pretty much all carbon. Its only half finished. But we've removed 150kg's from the previous weight 830 kg's (probably added some bits here and there though).
Power shouldn't be a problem, everything is spec'd for 1000hp but we'r going to run the small turbo for now... GT40 Progress has been slow as i've not moved it to the new garage yet. Soon as I do i'm sure we'll gain momentum with it. The problem is it usually ends in more things been cut off and less things been attached.
Heres 1 pic.
To add a bit of colour a few pictures from this week.
B series ram horn.
This should be around 600hp, its currently done an 11.8 at TOTB (road tyres) last year. Since gone bigger turbo, 1 of our inlet manifolds and a few other bits. We don't do everything on this car, there a few things we would do a little bit different. (silicone joiner flexy pipe to turbo etc)
Old 16-03-2011, 04:59 PM
Chip
Chip's Avatar
Sounds like it will be setting new records on its first outing if all goes to plan.
although it never does go to plan on the first outing, lol
but thats the best power/weight combination im aware of for any UK fwd car that is likely to emerge soon.
Old 16-03-2011, 05:23 PM
RickyLee53
RickyLee53's Avatar
1hp per kg is the target, its either make or break really. However it doesn't meet ANY drag racing classes. All the modern cars are heavy, so everything is 1000kg's plus. Dissapointing as limiting weight is worse than limiting power IMO. If the car's heavy it'll go slow, but it also needs more expensive parts. I.e. gearbox etc.
I'm hoping it'll go around the track*, hence the aeros and small turbo (full boost on the last lower spec engine was 4100rpm's (2.1 bar))
It will certainly not go to plan as you know, there are a few quick car's this year we'r involved in, hence me taking my time on my own.
I'll post a seperate thread at some point.
* In an insane undriveable but fun way.
Old 18-03-2011, 11:01 PM
Paul1982sco
Paul1982sco's Avatar
Nice looking intercooler what price would something cost?So what injectors and boost is lee's yellow ep3 running that it makes 420whp unmapped?
Old 19-03-2011, 12:42 AM
fogulbennett
Sorry get mixed up with the bhp it's 411 at crank not wheels and don't no what boost or injectors he did run a 13.8 in the damp last Sunday at crail tho
Old 19-03-2011, 04:01 PM
KnoxyGtt
T34 just kicked in Yo
KnoxyGtt's Avatar
Welding is mint, how long did it take to learn to weld with that skill level?
Old 24-03-2011, 05:33 PM
escort1989uk
Any updates of the exhaust and turbo yet?
Old 25-03-2011, 09:30 PM
RickyLee53
RickyLee53's Avatar
Exhaust is all done and has been for a couple of weeks, but didn't take any pictures while it was on the ramp.
Still waiting for the turbo from the states. Should be here by the end of next week, there currently on back order at the moment though. A shame the customer decided to change spec at the very last minute.
Old 25-03-2011, 09:41 PM
danneth
TORQUE!
danneth's Avatar
looking good rick, think i need to come see you this weekend
Old 26-03-2011, 06:47 AM
Paul1982sco
Seen the videos of the yellow ep3 on YouTube, brave man to be doing that with a unmapped engine. When its racing the pulser it sounds like he ended up with a misfire. Ricky what is your customer using the car for, track or drag? If it's drag I know of a quaffie dog kit forsale
Quick Reply: Ep3 Turbo build (plus some other honda stuff)
