My Escos Resto
My Escos Resto
Started what i thought was a little resto/ tidy up before this years show season. The car hadn't moved for about 2 years
took the side skirts to find huge amounts of rot forgot to take some pictures before the work started, heres how it stands now.
Front section repair under the front wing
rear quarter repair
repairs to the floor / inner seal
small repairs
inside the car under the carpet was bad too
repairs front section
rear quarter repairs
new sil fitted
couple of the poor car
it will need the same doing the overside, plus two new front wing and pretty much a full repaint. Should be ready for castle combe
rear quarter repair
small repairs
new sil fitted
Always good to see another Escort Coss restore thread.
The sunroof drains are shocking!! At the end of the pipe is a square of foam. Clever Ford thought this was a good idea! Thats why every escort rusts from the inside of the sill to the outside. On the std Escort theres a hole below the hinge. Pull the pipe through this hole and trim the end of so its nearly flush. Now the water will just drain to the floor. Repeat for the other side The rear ones are fine as they go into the rear vent behind the rear bumper and drain to the floor.
This was mine after doing the sill. I then trimmed it down so was nearly flush.
Had the sills replaced on mine to, I'm struggling to find a solution to find a way to reroute the pipe, got any more pictures of the result? And also how you made the lower square holes that holds the side skirts.
/Michael
/Michael
