Ford escort mk4 estate zetec turbo
post my project here.
it is a Ford Escort Mk4 estate, which I will insert an rs turbo engine in the car.
I thought it had hosted great to get some tips from you in england which is based on such type of cars.
a little picture of the car.
some old photo
some old photo
thanks
i thinking to have 200-250hp in the engine when its finish.
i thinking to have 90spec bumper on the car or cosworth bumper.
what do you think about it?
The first chassis to be finished and I take the engine and other stuff afterwards.
my english is not so god. i use google translator.
I need the website of the chassis parts.
what type of fuel injection system is the best to use when i going to have 250 hp?
i like the car to pauldonachyrs
some parts i have bought from burton power
HIGH PRESSURE OIL PUMP
brand new
the engien rs turbo
i need brand new pistons to the engine and con rod.
i thinking to paint the engine i the same color as the car are going to look out.
i thinking to buy KONI TOP ADJUSTABLE DAMPER and convertion to REAR BRAKE KIT: MK3/MK4 ESCORT and take cossie front brake on the car.
where can i buy Window & Door Seals to my estate to 5 doors cars?
are there any shops that sell yours type chassis part or do I cut from a donor car?
I only need to lower the car on the picture
are the convert kitt from mfi to efi ?
brand new
the engien rs turbo
Cracking on now if you have a look at the sticky at the top of the rsturbo room there is afew guides on what is required to do the cosworth disc conversions front and rear
Mark.
Mark.
some more photo
some engine parts.
some body parts i by from germany:
they have lots of parts for escort
welding
not so much has happened with the car
i hope i have more photo and info of the car to chrismes
some engine parts.
welding
the penal is going on next week
I'm going to overhaul calipter. and replacing wear parts inside the engine and gearbox
summer next year so are well kassori work done
