moonstone 3dr small update
Old 26-10-2014, 08:07 AM
  #881
Jay,
Sponsor
Jay,'s Avatar
God I can not believe Pete is still holding the car up Shame his work is spot I wont be using him and I am probably responsible for some of his tardiness seeing as i got him the race car work
Old 26-10-2014, 08:25 AM
  #882
cozzy jeff
cozzy jeff's Avatar
are so your too blame,
the only problem I see jay is that its gonna be awkward to get the drill in to do the rivnuts,i just hope I don't have to remove the turbo to give me enough room.
don't think ill be using spec r again myself.
Old 26-10-2014, 09:29 PM
  #883
cozzy jeff
cozzy jeff's Avatar
just a little update:
got the yellow paint done on the AP'S.
also got the front splash shields done(im still looking for a rear n/s one if anyone knows of one)
and the caliper brackets:
put the comps on as I was fed up of pumping up the old 3dr rims:
mike came round last week and wire in the harness he made for me:
fitted the turbo damper today:
that's about it for now,ill update again once my tanks turn up from spec r but don't hold your breath.
Old 28-10-2014, 09:57 PM
  #884
tracktoy
tracktoy's Avatar
looks awesome- what paint did you use on the calipers after?
Old 29-10-2014, 06:48 PM
  #885
siscossie
3-door moonstone
siscossie's Avatar
Looks brilliant mate got the parcel cheers spot on
Old 29-10-2014, 08:10 PM
  #886
cozzy jeff
cozzy jeff's Avatar
cheers mate,i used this stuff,goes on really nice.
http://www.ebay.co.uk/itm/2009879768...%3AMEBIDX%3AIT
nice one mate im glad your happy with it.
Old 05-11-2014, 07:24 PM
  #887
cozzy jeff
cozzy jeff's Avatar
the last of my tanks came today
still waiting on the filter and the retaining ring for the header tank,heres a couple of pics sent me before he posted them out.
Old 09-11-2014, 06:05 PM
  #888
cozzy jeff
cozzy jeff's Avatar
spent a couple of hours on the car today got the last of the tanks on and made up the braided hose,really pleased with the result,the tanks fit great.
also managed to source a good n/s dirt shield,these are hard to find now.
cleaned up and fitted.
one thing I had to check today(after mike mentioned it)is if my 4x4 brakes were going to fit with the 2wd backing plates that I had made,as you can see from the pic they work great.
Old 09-11-2014, 06:43 PM
  #889
Jay,
Sponsor
Jay,'s Avatar
Tip top as per jeff
Old 09-11-2014, 06:45 PM
  #890
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
Work of art this car is
Old 09-11-2014, 07:34 PM
  #891
Cossy Mike
Cossy Mike's Avatar
Perfect
Old 09-11-2014, 07:46 PM
  #892
cozzy jeff
cozzy jeff's Avatar
Originally Posted by Jay,
Tip top as per jeff
Originally Posted by saphcosmike
Perfect
cheers lads I try my best
gonna have the injectors sent away for a clean as soon as they get back to me with payment details,then have the rear calipers refurbed then ill be able to get some some fluids in
Old 16-11-2014, 04:24 PM
  #893
cozzy jeff
cozzy jeff's Avatar
bit done today,got the clutch bled.
got the exhaust clamps fitted,ignore the exhaust I know it shit.
rs500 boot spoiler fitted,cars starting to look complete now.
Old 16-11-2014, 04:40 PM
  #894
siscossie
3-door moonstone
siscossie's Avatar
Looking great mate
cozzy jeff (23-11-2014)
Old 23-11-2014, 05:12 PM
  #895
cozzy jeff
cozzy jeff's Avatar
only had a couple of hours on the car today,i managed to get the heat shield and strut brace fitted.
also had the injectors back this week,all good now.
Old 27-11-2014, 07:18 PM
  #896
fezzajsy
fezzajsy's Avatar
very nice
Old 29-11-2014, 09:27 AM
  #897
adam151082
adam151082's Avatar
Originally Posted by cozzy jeff
Hi Jeff, sorry to hijack your thread but what is this part called? Did you strip yours down?
Old 29-11-2014, 10:13 AM
  #898
cozzy jeff
cozzy jeff's Avatar
Adam them bolts are from the abs unit,as you can see I've took the bolts out and the fittings that go in the underside and had them zinc'd, I wouldn't go stripping it down if you can help it.
I opened one up a while back and damaged it so had to source another.
Old 29-11-2014, 11:08 AM
  #899
adam151082
adam151082's Avatar
Sorry Jeff i ment this part
Old 29-11-2014, 11:27 AM
  #900
cozzy jeff
cozzy jeff's Avatar
im sure its just bias valve to adjust the pressure to the rear brakes,i could be wrong if anyone would like to but me right.
I didn't strip it I cleaned it up with a wire wheel and blanked the ends off then had it zinc'd.
Old 29-11-2014, 12:44 PM
  #901
Jay,
Sponsor
Jay,'s Avatar
Correct young man
cozzy jeff (29-11-2014)
Old 18-01-2015, 06:08 PM
  #902
cozzy jeff
cozzy jeff's Avatar
not touched the car for a few weeks but today mike dragged me into the rain/snow to fit my 100mm top feed cooler,cheers mike.
also had the rear calipers refurbed by biggred recently.
mintex pads for the AP'S
cone filter sock
couple of sensors and dimple sump plug from MSD
Old 18-01-2015, 06:33 PM
  #903
Cossy Mike
Cossy Mike's Avatar
Gonna be some machine when it's back together
Old 18-01-2015, 07:57 PM
  #904
scottyrs
DURHAM RSOC
scottyrs's Avatar
Stunning mate not long now
Old 18-01-2015, 09:49 PM
  #905
COLEYST200
COLEYST200's Avatar
It's looking very good mate well done
Old 20-01-2015, 03:27 PM
  #906
cozzy jeff
cozzy jeff's Avatar
im sure we said that last year sometimes I feel like im going backwards
cheers mate
had my thermostat housing back from the machine shop tonight they've drilled and tapped it to fit the sensor for the stack gauge.
Old 21-01-2015, 07:33 PM
  #907
Have you not finished this yet lol.
Its getting there matey.
Old 21-01-2015, 07:39 PM
  #908
cozzy jeff
cozzy jeff's Avatar
I know Glenn it's dragging out now mate, as long as I'm waiting for spec r it'll never get finished.
Old 25-01-2015, 06:26 PM
  #909
cozzy jeff
cozzy jeff's Avatar
spent a few hours on the car today,i had bought an alloy drop bracket for the alternator.
while I was under the car I wasn't happy with the fit of the top feed cooler,one side hit the bumper and no amout of adjusting cured the problem.
so had to get the grinder out.
after a bit of a fiddle everythings sorted.
very little room down there now.
next job,big brakes for the rear when my tax return shows up.
Old 25-01-2015, 07:58 PM
  #910
Cossy Mike
Cossy Mike's Avatar
Now that is close
Old 25-01-2015, 08:06 PM
  #911
cozzy jeff
cozzy jeff's Avatar
I know mate,i had to mount it without the rubbers or the pulley would kill the fans
Old 26-01-2015, 07:34 PM
  #912
BRAMMER
BRAMMER's Avatar
I had to remove the clips holding the loom behind the crossmember to pull forward enough and mines close too pal at least its in
Old 26-01-2015, 08:26 PM
  #913
cozzy jeff
cozzy jeff's Avatar
really that far forward?
how can they advertise it as(no cutting or drilling required)
I cut and drilled till I was happy that it was secure.
ideally if the mounting holes where angled front to rear like the rad maybe I could have got a little more room between the fans and pulley.
Old 26-01-2015, 08:38 PM
  #914
Its getting there Jeff.
Old 26-01-2015, 09:04 PM
  #915
cozzy jeff
cozzy jeff's Avatar
it is mate,get the brakes on then theres no reason why I cant try and start it.
ive got to get onto pete at spec r to see whats going on with the last of my bits its been 9 months now
Old 27-01-2015, 09:50 AM
  #916
Jay,
Sponsor
Jay,'s Avatar
My god Jeff you and Chris must have the best 3 doors on the planet
cozzy jeff (27-01-2015)
Old 27-01-2015, 01:09 PM
  #917
Staffi
Staffi's Avatar
Awesome Jeff
Agree totally with Jay too
Old 27-01-2015, 05:53 PM
  #918
cozzy jeff
cozzy jeff's Avatar
im looking for the screw on fitting that holds in the level sensor in the header tank if anyone has one lying about,looking to have one made in aluminium.
Old 01-02-2015, 05:55 PM
  #919
cozzy jeff
cozzy jeff's Avatar
spent a couple of hours on the car today heres some pics.
got all the abs sensors cleaned up and plugged in:
looks a bit cleaner under there compared to when I bought it.
due to fitting the top feed cooler the cooler/throttle body hose didn't quite fit right so got onto roose to order another,i said just send out the exact same hose as you sent out the last time,this is what turned up
bottom hose is the new one,as you can see the dump valve take off is in a different place,so now I have to make up a new vaccum hose.
had to trim the hose till I was happy with the fit,new stainless jubilee clips all round.so im pretty much back to where I was before fitting the cooler just waiting for my 300mm rear brake conversion from martin so I can get some brake fluid in and try and get it started
Old 21-03-2015, 11:38 AM
  #920
munz
munz's Avatar
Beautiful job Jeff! A credit to your dedication.
A few pages back there is a picture of the exhaust side of the engine and I noticed a knock sensor. Do you know where I can buy these or was it already on there?
Ash
Quick Reply: moonstone 3dr small update
