1991 Ford Scorpio 2,0i CL -> 2,9i 24v Ghia Cosworth
My Ford Scorpio project
I bought this Scorpio couple of months ago, my plan was just to keep it as my every day runner , and not put so much work in it..... but that failed
this is how it did look when i bought it
a little rust , a dodgey clutch and som other minor problems
removed the gearbox and changed the clutch and the bearing inside the flywheel
put on some white indicators and facelift tail lights + one brand new ford reflectors plate
New bushings to the stabilizer bar
painted a RS kit and the mirrors
Fitted the skirts
Painted one of the rear bumber corners and the front spoiler
bought and changed som parts
new gearleaver cover
new windscreen , but it broke a week later, new heated one soon to come
sanded down a set of cosw alloys , painted them and put on some new tires
Picked up one of those and fited cosworth front and rear suspension
Dohc out
Cosworth in
Leather interior(doorcards will be fitted someday)
Sanded down and primed a set of Rocker covers
Fresh paint
more new stuff
new rear quarter , still need the right side.. found one on ebay but the seler would not ship it to norway
Fitted the skirts
Dohc out
Cosworth in
Fresh paint
more new stuff
Very long time since my last update at this forum , but here it comes
Bought a lot of parts and fitted them
EBC Red stuff brake pads
Sierra Cosworth 4x4 clutch
Painted some stuff
Cleaned my gearbox and fitted some new parts
some gaskets
Vectra V6 injectors
CD changer and some restored speakers
Painted some fuel components and the rear bumper
New fuel hoses and fitted the painted parts
New windscreen
Cleaned and sealed interior
Pics from the local ford meeting
I realy want another set of rims with i wider edge on them but i havent found one in my price range yet
Painted some stuff
some gaskets
Vectra V6 injectors
New windscreen
REALLY nice work!
I want to do that to my scorpio 24V too. Where did you get the spare parts from? Im from germany, here you can't even buy a gasget for the scorpio, there are no more parts available at ford. Is this better in Norway? Where did you get the gasgets for the valve cover?
What Paint did you use for the underbody? Something special protecting for rust?
Sorry for my bad english
Greeting,
vuli
Greeting,
vuli
REALLY nice work!
Greeting,
vuli
Greeting,
vuli
that sounds good, i think i will call ford germany in cologne and ask for parts.
I just noticed that you used injectors of a vectra v6? are there any advancements using this injectors? can you give me the part number of that part?
Thank you,
vuli
Thank you,
vuli
Just search for vectra 2,5 injectors on ebay UK and you will find them, I havent noticed much yet but im only using stock exhaust at the moment and stock airfilter. Im going to swap exhaust and another airfilter in the spring, I think it will make more difference then
Update of what i have done over the last weeks
Fitted a New radiator with electric fans from the 95-98 Scorpio
Fittet a refurbished thermostat housing and a new thermostat.
Fittet a new Expansion tank with a new fluid level sensor
Also had the airfilter box holder painted
And Motomobil in Germany managed to source me one new towhook cover.
Had that painted and then fitted it.
Pics
(need som more cleaning and paint in the engine bay i see :P
Pics
Here are some pics from rest of my collection.
I just cant get enough of them
My 1994 2.0
My 1993 2,9 Estate
Whit one of a kind front end built by me
And a couple of my daily driver
My 1994 2.0
My 1993 2,9 Estate
right decision throwing out that viscous cooling fan. Can you tell me more about the wireing? I have the electrical fans of a Scorpio Mk2 1995 that i wanted to use but i am not clear about wireing it with the temperature sensor.
I would be glad about a quick wireing plan.
Thank you,
vuli
Thank you,
vuli
Turbocharging Technician
you need a termo fan switch, wire the fans permaenatly live, and earth them through the switch. put the switch in the top hose. Nice project, you have just reminded me that i need to do something with my cooling fan!
hello chaffe, thanks for your reply.
Which thermo fan switch do i need? i think it should switch at about 95 °C, so i picked out this one:
http://cgi.ebay.de/ws/eBayISAPI.dll?...m=380342147942
I planed to put it directly in the hose, i wanted to make a hole in it, put the thermo fan switch through the hole and fix it with a nut inside of the hose.
otherwise i would need a hosing out of metal for the switch like mr. scorpio used. which one would be that?
Thank you very much,
vuli
vuli
Looking good mate, good to see something different getting the treatment How you get on with the bug eyed Scorpio in that weather? They rust quicker than you can think about it over here
hello all, I have a turbo diesel Ford Scorpio 2.500cc in 1991 and it turns out that the rope broke the lever to open the hood and I was wondering if someone could help me very urgent
If someone helps me appreciate it a lot xdxdxdxd
Two years since my last post here , i think its time for an update now :P
Sold my 24v Cos last summer, some last pics
Still got my Estate , the red 2,0 and froggy now fitted a 2,3 16v in that
1993 Ford Scorpio 2,9 12v Ghia
1994Ford Scorpio 2,0i CLX
1995 Ford Scorpio 2,3 16v (My everyday car )
1986 Ford Scorpio 2,8 GL tracktoy
Thanks to PF mag for photo
And my 1980 Ford Capri soon to be restored
And also bought myself a 1975 Cortina GL estate mk3.
Undergoing some surgery right now.... it was quite rotten, but just the rear end still to do now
Thank you
Nice and comfy cars yes
v6 mt75 is quite hard to find here too
Infact I keep looking through this thread. You're making me want a granada now I might look out for one as a next project when I get my apprenticeship They look so nice!
markk
18
17-08-2015 05:19 AM
