Mk6 JWRC fiesta cosworth
Old 29-01-2010, 06:25 PM
  #401
doctor stavros
AMG C32
doctor stavros's Avatar
lookin great. the fab work is awesome
Old 29-01-2010, 07:22 PM
  #402
erjones
erjones's Avatar
So you up in Scotland now then? or have i got the wrong day lol
Old 29-01-2010, 09:42 PM
  #403
M K
M K's Avatar
Driving up Sunday ready to be at Andrews Monday morn, gonna stay in the premier inn by his Sunday night
Old 01-02-2010, 05:23 PM
  #404
M K
M K's Avatar
Well I've been up to see the cars progress at Andrews and sort out where I want my seat and pedals and steering wheel etc and I am chuffed to bits with it
the work is fantastic and done to such a high standard, went over a few things to be done on top like a fuel tank and bulkhead fuel line fittings and brake fittings etc which is easier to do while the car is there, can't wait to get it back even though I am in no rush so take your time guys lol,
big thanks to Andrew and Scott the fabricator who tailor fitted everything for me today lol, and cheers for the beers and games of pool mate, I would never leave that workshop if it was mine
thanks again,
Got some more pics I took while I was there that il upload later,
one problem is though............
I have been stuck in Gretna services on the A74 broken down with no tools on me for 3 hours now and I'm still sat here waiting for the RAC!!!!!!!
Think the thermostat on my escort stuck shut as the water hose before it was blown up like a balloon and the car won't rev over 3k and is totally gutless and won't even do 60mph!!!!!!! Fucking thing and I'm still 340 miles away from home so it's gonna be a long day I think
thank god I bought recovery on friday that takes you anywhere you like in the uk if it can't be fixed. Best £70 I ever spent
pics soon.....
Old 01-02-2010, 05:29 PM
  #405
gus
gus's Avatar
o dear, ask andrew if you can borrow his focos coutersy car
Old 01-02-2010, 06:05 PM
  #406
COLEYST200
COLEYST200's Avatar
thats is not good about bracking down all the best with getting home
Old 01-02-2010, 10:05 PM
  #407
ESCYSCOTT
ESCYSCOTT's Avatar
Did you beat Andy at pool......he doesn't like to be beat!! Eh Andy
Old 02-02-2010, 12:38 AM
  #408
M K
M K's Avatar
i should of as it was only laid up doing nothing
cheers fella, got home about 1am in the end
na i didnt, only had 2 little bottles of stella so didnt have my eye in you know
Anyway the RAC turned up 2 and a half hours after calling them and after a bit of head scratching it turns out it was the cat that caused the breakdown
it had starting knocking saterday so i tried to order a new one but they couldnt sort one for me till monday so i thought its only knocking so doesnt matter if i do it tuesday when i get back but oh no.....not this time
it had broken up inside the box and got jammed inside the exhaust and got so hot it formed a nice bung shape and stopped pretty much all exhaust gasses getting out hence the pressurised cooling system and the complete loss of power, so the fella unbolted the exhaust and broke up all the cat stuff inside and got it all out so the box was empty, put it back together and bobs your uncle its good as new and i was on my way after a 3-4hour hold up.
on the plus side though the car has just past its mot last monday and the new cat i was going to sort in the morning is about £100, which i now wont bother with till before the next mot as it doesnt knock anymore as there is fuck all in it
the years breakdown cover only cost me £70 so apart from time wasted its saved me a few quid for now so not all bad
cant find the camera lead to upload pics and im too tired to look so will post them when i get up and can be arsed to find it lol
nite all
Old 02-02-2010, 08:08 AM
  #409
erjones
erjones's Avatar
See, if you had said you were a pregnant female they would have been there much soon lol
Progress sounds good, any more pics of the updates?
Old 02-02-2010, 09:34 AM
  #410
M K
M K's Avatar
here is all the random pics i took yesterday while i was there and a few things we went over about whats still to be done etc,
the work is fantastic and its just mental seeing it up close
sorted out my seat position and pedal box position which is very tight for space as ideally peddles need to go forward a knats c*ck but they cant, but i think its just about going to be ok,
luckily the gear lever was ok where the box sat so they did not have to mod the cradle to come back further so that saved a job and also took all the measurement for the steering wheel position, although its a lot harder than you think just holding a wheel and deciding if its where you want it etc, as it all seems wrong being a lot further back in the car than a standard item but its all noted down so the guys can carry on with the build :cool!:
Whilst we were there Andrew suggested a few things to do while he has the car and a few of them are a must as i have encountered problems on my last build that this will resolve,
1st - have male-male -6 through bulkhead connectors welded in rather than on a nut as they tend to come loose very quickly and once everything is in be a pain to get to and tighten especially if your working alone, so there are 2 going in the bulkhead and 2 more going in behind the seat as this time round im having the fuel pumps and filters mounted under the rear of the car,
the brake lines from pedal box to all four corners will also be welded in place on each corner with male-male connectors again to stop loose spinning fittings when removing and re fitting.
2nd - Andrew is making me a fuel tank that will be at the very back of the car in the boot area between boot panel and cage diff pick ups. the tank will be about 200mm high and roughly in the shape of the boot space available giving a calculated capacity of roughly 50ltrs so more than big enough,
The tank will then have a sump through the boot floor with the outlets and fuel return in aeroquip fittings and the pumps mounted next to it all nice and neat.
3rd - The decision to go chassis mounted has been scrapped! after getting to see it all close up its really just going to be a hinderance as Andrew did first say, it will make it a lot harder to remove the engine, re fit the engine and work in the engine bay, along with slightly more excessive vibration through the shell due to the mountings so we are going to use some new vibra technics mounts and keep it all as standard there,
I am sure there's things i forgot to mention but thats enough writing for now, if you want to know anything particular just let me know, here is the pics i took while i was there,
Old 02-02-2010, 09:48 AM
  #411
Drizz
Enthusiast
Drizz's Avatar
Wow!
Old 02-02-2010, 10:16 AM
  #412
erjones
erjones's Avatar
Nice update, not much distance for the air to travel from intercooler to inlet lol very nice ineed!
Old 02-02-2010, 12:42 PM
  #413
M K
M K's Avatar
na just needs a slight angle sorting so i dont get a kink in the hose, but it lines up pretty good considering how far off they usually are,
Old 02-02-2010, 03:44 PM
  #414
andy escos
andy escos's Avatar
gonna be one mental little car when done great fab work
Old 02-02-2010, 03:56 PM
  #415
-beefy-
formerly beefy-rst-2
-beefy-'s Avatar
looking great marc ,
Old 02-02-2010, 05:10 PM
  #416
stu21t
stu21t's Avatar
looking very very good
out of interest what sorta price tag does a chassis build like this cost?
pm if you like.
Old 02-02-2010, 05:35 PM
  #417
COLEYST200
COLEYST200's Avatar
nice very nice
Old 02-02-2010, 05:42 PM
  #418
BlairM
BlairM's Avatar
Progress is looking good.
Old 02-02-2010, 06:07 PM
  #419
MikeR
MikeR's Avatar
fantastic as all these up dates are Marc,
Mike
Old 02-02-2010, 07:33 PM
  #420
M K
M K's Avatar
Mike
yeah...........?
Old 02-02-2010, 07:35 PM
  #421
MikeR
MikeR's Avatar
Originally Posted by M K
yeah...........?
translated l said that this is a fantastic project and l love reading about it and all the up dates
Mike
Old 02-02-2010, 07:54 PM
  #422
M K
M K's Avatar
Ahhhhh I get ya lol thought you
had missed a bit off the end,
Old 02-02-2010, 07:56 PM
  #423
duncansharp76
duncansharp76's Avatar
slowly getting there dude, keep it up and cant wait to see this one finished
Old 02-02-2010, 08:03 PM
  #424
M K
M K's Avatar
pm if you like.
It really depends what you want done as the price can vary hugely
Old 02-02-2010, 08:14 PM
  #425
c20tbo
c20tbo's Avatar
Looking very good, what Rack/Coluum you using? ive also had issues with foot room for my pedals on the 106, Martoon has had to go with floor mounted pedal box and move seat back slightly, im also hoping to use Corsa c eps, got the coluum and controler just needs mounting to suit.
Old 02-02-2010, 08:25 PM
  #426
M K
M K's Avatar
I'm using a custom column Andrew is making up and cossie 4x4 rack and grp a knuckle,
I think I'm going to stick with the factory cossie power steering set up but use a
modified grp a pump
Old 02-02-2010, 08:34 PM
  #427
cossiejsy
cossiejsy's Avatar
its looking very smart
Old 03-02-2010, 12:17 AM
  #428
CarbonRick
PF Village Idiot
CarbonRick's Avatar
Looking great Marc.
Old 03-02-2010, 12:54 AM
  #429
dug112y
passionford pro
dug112y's Avatar
this build is just awesome...love it
Old 03-02-2010, 03:12 AM
  #430
TimC
TimC's Avatar
Out of interest, do you or andy still have any of the chassis leg parts that where cut off, if still in good condition forsale?
Old 03-02-2010, 05:01 AM
  #431
M K
M K's Avatar
you would have to ask Andrew mate but your welcome to them if he has im sure,
Old 03-02-2010, 03:53 PM
  #432
Looks fantastic ,Marc before you bring it home i would suggest a splash of etch primer on all the bare metal
Old 03-02-2010, 05:55 PM
  #433
M K
M K's Avatar
Yeah the whole shell us gonna be done before it comes home mate even if it's by
rattle can to get it home protected etc
Old 05-02-2010, 05:48 PM
  #434
M K
M K's Avatar
Any update tonight Andrew,
also did you get my pm about wanting to got for roll bars front and rear now?
Thanks Marc
Old 06-02-2010, 07:00 PM
  #435
RAT8OY
RAT8OY's Avatar
Mark,
I was blown away by the pics you sent me by text but jesus, to see them in this quality!!!!!
Good fuckin skills son! You had better get that shotgun cut down asap mate, funds needed lol!
Old 07-02-2010, 09:22 PM
  #436
M K
M K's Avatar
Originally Posted by RAT8OY
Marc,
Well you knocked me out the game with your FWD monster, so i had to step up my game a bit to keep up
glad ya like it, il let you know when its back so you can come over for a proper butchers
Old 10-02-2010, 01:01 PM
  #437
RAT8OY
RAT8OY's Avatar
Christ yeah, let me know and I will be straight round. Although dont be suprised if I ask for a few moments alone to 'study' her in more detail! LOL!
Old 10-02-2010, 01:06 PM
  #438
COCHYN
COCHYN's Avatar
Looks trully mental that, so many fine details. I'd happily spend a whole day staring at all angles of the car, probably find something new every time
Old 10-02-2010, 01:33 PM
  #439
M K
M K's Avatar
that's what i was like when i was up at Andrews the other week, must of walked round it 50 times just looking at different things every time.
i want to bring it in the house when i get it back home
Old 10-02-2010, 01:39 PM
  #440
M K
M K's Avatar
small update,
I have decided i want to run front and rear grp a bladed anti roll bars, which was proving to be difficult as apart from brand new kits for approx £1600 the pair i haven't had any luck finding any, but i emailed a fella on www,rallycarsforsale.net as he was selling some other grp a parts and asked if he had the roll bars still and he has so i am waiting for them to be removed from the car and then hopefully i will have them on their way up to Andrew late next week, they may need a blast and new zinc plating etc i imagine but there a shed load cheaper than new
Quick Reply: Mk6 JWRC fiesta cosworth
