s2 erst project??
s2 erst project??
have a s2 erst movin house havent got room for it ne more so think it time to say bye, bottom end used in another car same wit box
s2 erst (no bottom end or gearbox)
got some zetec bits:
2l throttle body
water pump
coil pack/mounting bracket
injector loom
16v rocka cover
fuel rail and injectors
engine loom
power steering pump
idle sensor
cvh rst:
starter motor
master cylinder
oil feed t piece
alternator
2x front brake caliper (4)
lower cross member
sump
4 low comp mahle pistons
rocker cover
ecu
throttle body
metering unit
header tank
coolant kit
rad
cylinder head (fully assembled)
mfi inlet manifold
heater matrix
engine mounts
fly wheel and clutch
sparco front upper strut brace
momo steering wheel
1x recro seat
full koni suspension kit
full rs body kit 80 spec
water pump
gear box brackets
cross member
instrument cluster
oz super turismos 15" silver
any one up for a challage? offers? asap movin soon
2l throttle body
water pump
injector loom
16v rocka cover
engine loom
power steering pump
idle sensor
cvh rst:
starter motor
master cylinder
oil feed t piece
alternator
lower cross member
sump
rocker cover
ecu
throttle body
metering unit
header tank
coolant kit
rad
mfi inlet manifold
heater matrix
engine mounts
momo steering wheel
1x recro seat
water pump
gear box brackets
cross member
instrument cluster
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
SMILER258
28-09-2015 09:04 AM
