time for T6 !! SCS starting mapping sesion !! SCS built Bastos escos trackcar !!!
right, my friend brought a tidy escos about a year ago and since then it has been sent to SCS for a full track ready built !
it started out as a rally car which was then sold with all the good bits robbed off it and with standard engine and running gear!
this is where we began;
the interior needed a freshen up so this was done in diamond white along with the engine bay
then started on the interior, feul tank went in first then all the carbon fibre door cards were made up.
then went about fitting the dash, this was chopped up to save weight and all necessary guages were fitted.
the shell needed to be back on wheels for easy movement!
so a 6 degree read beam was fitted along with the 7inch diff, driveshafts and mag bilsteins! (bilsteins for the front too !)
whilst all this was happening a brand new 6speed r+d dogbox was purchased and a p8 ecu! to go with the p8 a pectel board was brought for the antilag
two sparco pro 2000 seats were purchased and fitted along with a hydraulic handbrake !
now it was time for harvey to work his magic and get the engine built
the engine consisted of;
200 block with 6 longstuds
standard,standard crank
standard rods
cosworth pistons
a ported 4x4 head with
double valve springs and
SCS spec cams
this was then dynoed and made 440 bhp at 26psi and 385 lbft torque!
when removed from the dyno it was built up onto the cross member with the front diff on and the gearbox fitted
now its ready for the car !!!!
to day we fitted rear brakes which were 300 mm 4pot ap racing !
heres some pics
brakes fitted
dropped the rear looks a million times better
one of martins and harveys together !!
well thats it for now will try and get updates and more pics asap
cheers jim
standard rods
cosworth pistons
SCS spec cams
heres some pics
brakes fitted
cheers jim
I've got a lovely set of 18" mag WRC Cromodoras in white to give it the full Snijers look.Shame one of em is buckled,they would look the danglies.
track car
hi mate remember seeing this on the lift when i was over at harveys last year picking up my car love it realy like the photo of it and harveys car side by side . when do you hope to get it on track then . will you be at ford fair . you might take me a blast.
ford fair
hope to bring my car mate to ford fair i am going to the ring now soon with rainbum so that should be fun. just starting to get used to driveing it now its a bit of a handfull it lights up the tyres comeing off round abouts so you neen to be thinking about what your doeing. if my plans go ok am going to be building a track car my self well sorry harvey will be building a track car for me cus am not much good way a spaner.going to put my 680bhp engine into it and get harvey to build me a 450bhp for my road car .will all depend on the deal i can get with the guy with the shell .
your engine wont get done with comments like that !
Awesome car mate! Would be nice to try and find the Grp A Speedlines that it would have worn!
Whats completion time on this one? and when the fook is Harvey's coming out to play, still looks amazing!!!
Good news on Harvey's Escort!
I'm sure your probably aware mate but look on www.rallycarsforsale.net there are always sets going on here! Being Magnesium they will obviously be alot LOT lighter than 18's Comps too!
these gibbs' are a confident bunch eh
but spose its not hard to whoop you
Jim,car might not weigh much but the last time I seen little Martin he wasnt that littleJust as well he aint karting no morelolsee you have been busy anyway Jim!get it sorted and get them over!
