Granada 2dr to be cosworth
Here is all that was done from beginig
She arrived to me in 8 month 2006
After few weeks begins restauration
Before painting
After painting
Wheels
Litle comparation
Build up begins
solving problem
Build up almost over
attempt off lowering
for now problem fixed with new springs
summer photosession
puted on front brakes from granada 2.8
old
new
prepared for registration
finally found front lip from granada 2.8
befor
after
donor car for engine and other things
this out
this in
but without this
litle electric
almost over with job
finished
car is lowerd with custom made springs, front -8 rear -5
in plan is lowering front end for -1 and custom made shocks
winter setup
and here we go again
and new donor
this
from here
is going here. I hope
and sierra striped
Before painting
After painting
Wheels
Litle comparation
Build up begins
solving problem
summer photosession
old
new
befor
after
this out
this in
but without this
litle electric
finished
winter setup
and new donor
this
from here
and sierra striped
No wonder i've never seen a mk2 3dr granny. they never made them over here as i have just been informed by my old man. they only made mk1 3dr's here. any updates on it yet.
Fast Ford snapper
2 Ade: in croatia this is the only one , however people talk that there are still few of them in croatia but I have not seen any of them. So for now this is the only one
here are few from Germany, but they are to expensive
http://suchen.mobile.de/fahrzeuge/sh...e&pageNumber=2
http://suchen.mobile.de/fahrzeuge/sh...e&pageNumber=3
litle update
started wuth door and stop its to cold outside
but its not cold for ordering few things
Wiltec intercooler
specifications:
connection radius (in mm) 60,00
net size (in mm) 550 x 230 x 65
total dimension (in mm) 700 x 230 x 65
colour Alu polished
maximum pressure (in psi) 45,00
weight (in kg) 6,16
Spark plugs
Bosch 044
Flow 200 Litres per Hour @ 5 Bar
Belts
Oil cooler
Spec:
* 19 Row Core
* 3/4-16 (-8AN) fittings size
* Full filter relocation kit (incl. all nuts, bolts and brackets)
* 3 Reinforced braided stainless steel flexi oil lines of 3 different sizes, to insure adequate length for various installs.
Hose 1: approx. 125cm (connector end to connector end)
Hose 2: approx. 145cm (connector end to connector end)
Hose 3: approx. 165cm (connector end to connector end)
Knock sensor
Sensor kit
Dizzy Cap & Rotor Arm, Phase Sensor, Crank Sensor, Fan Switch, ECT Sensor (Blue), ACT Sensor (Brown), Water Temperature Sender, and a set of Ford 071 Spark Plugs
Head set
1X YB0611 GROUP A HEADGASKET
1X ROCKER COVER GASKET
2X ROCKER COVER HALF MOON SEALS
2X CAMSHAFT O’RINGS
2X CAMSHAFT OIL SEALS
10X HEADBOLTS
1X INLET MANIFOLD GASKET
4X EXHAUST MANIFOLD GASKETS (1 SET)
1X ECT HOUSING GASKET
1X PLENUM CHAMBER GASKET
1X THROTTLE BODY GASKET
1X THROTTLE BODY ELBOW GASKET
1X THERMOSTAT GASKET (2WD ONLY)
1X THERMOSTAT O’RING
16X VALVE STEM SEALS
thats all for now
Wiltec intercooler
specifications:
colour Alu polished
weight (in kg) 6,16
Spark plugs
Bosch 044
Belts
Oil cooler
Spec:
* 19 Row Core
Knock sensor
Sensor kit
Head set
2X CAMSHAFT O’RINGS
10X HEADBOLTS
thats all for now
