V8 Sierra 2WD
Old 25-11-2016, 09:41 PM
  #561
costina
Live long and prosper!!
costina's Avatar
Good old r tech welder i see you have Mark.
Good units they are i have one of there tigs too.
Old 25-11-2016, 09:46 PM
  #562
GrahamGarner
GrahamGarner's Avatar
Just sold one on eBay myself, lovely little tool.
Old 03-12-2016, 05:04 PM
  #563
moondustka
Boooost!
moondustka's Avatar
The things I would make if I had a CNC machine. Thats diff cover is lovely...
Surely, now you've made one, it's saved in the computer and it's easier to make the second?
Old 03-12-2016, 06:22 PM
  #564
Mark V8
Mark V8's Avatar
Thanks mate, it would be much easier to make a second one.
Still very time consuming though, no way I could make any money out of it with the equipment I have at work !
Wheels have been painted the correct colour
Can't believe the amount of black wheels at the wheel recon place waiting for collection by blind people
Old 04-12-2016, 09:39 AM
  #565
costina
costina's Avatar
Wheels are best in silver.
Looking good.
Mark V8 (04-12-2016)
Old 06-12-2016, 04:52 PM
  #566
moondustka
Boooost!
moondustka's Avatar
Not a fan of black wheels either.
They're nice though
Old 06-12-2016, 06:17 PM
  #567
Mark V8
Mark V8's Avatar
Finally finished bullshitting the outside of the diff cover, just need to get it anodised now...
Now looking at how to sort out drive shafts, might try and adapt these Jag bits to take the standard Cossie ones.
Old 06-12-2016, 08:54 PM
  #568
timbhp
timbhp's Avatar
looking good keep up the great work
Mark V8 (29-12-2016)
Old 29-12-2016, 08:24 PM
  #569
Mark V8
Mark V8's Avatar
I don't like the look of the off the shelf drive shafts to fit Jag diff, plus they are expensive at over Ł800 !
My cunning plan will probably save me bugger all as the steel cost Ł200
Bohler M238 DIN 1.2738 pre hardened with approx. 150,000 psi tensile strength
Should look like this when machined, although the splines turned out to be a pain in the arse to figure out and cost me more cash for a form cutter.
Old 29-12-2016, 08:29 PM
  #570
markk
markk's Avatar
I had them on my 3dr when i had one of the first jag diffs in the early 90s, no shit uj joints, just std 2wd shafts.
Old 29-12-2016, 08:34 PM
  #571
Mark V8
Mark V8's Avatar
Not done anything with the stub axles, but have gone into work over Christmas to make a new gearbox cross member.
Push start button ad bugger off for a few hours
Flipped over to do other side
Bugger off again for a few hours
Needs chopping out from supporting scrap material and some more machining, but looks nicer and weighs less than the fabricated one.
The following 2 users liked this post by Mark V8:
H3lsing (29-12-2016), XR4i - Sebastian (15-01-2017)
Old 29-12-2016, 10:24 PM
  #572
costina
costina's Avatar
Better than sex. Well really close eh...
Old 07-01-2017, 05:47 PM
  #573
Mark V8
Mark V8's Avatar
More Saturday tinkering.
Just need to tidy it up and get it anodised now.
Old 07-01-2017, 06:26 PM
  #574
costina
costina's Avatar
Always enjoy your updates Mark.
Looking good.
Old 08-01-2017, 08:44 PM
  #575
whizzisat114
whizzisat114's Avatar
Brilliant work as always
Old 15-01-2017, 01:42 PM
  #576
rwd_fiesta
rwd_fiesta's Avatar
I admire your skill, attention to detail and patience. Awesome project.
Mark V8 (29-01-2017)
Old 29-01-2017, 09:37 AM
  #577
Mark V8
Mark V8's Avatar
Confession time
Our lathe at work is pretty ropey and to turn the stub axles would have taken an age, so I got a guy up the road to turn them on a CNC lathe for a bit of cash in hand.
Results of the cheating are back.
I now need to cut the splines using a dividing head on a milling machine, problem being our best dividing head is too small to hold the flange on the stub axle.
Round the back of the big surface grinder was a bigger one that has been left there for at east 20 years untouched !
Dragged it out for a look.
After a fair bit of time cleaning and oiling.
Not got any further than that with stub axles as was skimming the rust off drive shafts on lathe at the same time.
Also got my bits back from anodisers, unfortunately the weld shows on the diff cover and I'm going to try and find an oil fill sticker to hide it up.
Anyone know where I can get custom high temperature stickers made ?
I want one that follows the curve of the radius on the oil fill hole...
Old 29-01-2017, 09:47 AM
  #578
Caddyshack
Caddyshack's Avatar
Beautiful work, try Dave username Monster on here as he does bespoke stuff, done a fair bit for me recently and he is brilliant.
Old 29-01-2017, 09:50 AM
  #579
jonfoc
jonfoc's Avatar
I'd be giving DMB graphics a shout. Parts look great
Old 29-01-2017, 10:26 AM
  #580
Amazing work matey,keep it up.
Old 04-02-2017, 10:53 PM
  #581
Mark V8
Mark V8's Avatar
All that time pissing about cleaning the old dividing head was wasted
I need to cut 19 splines, the dividing head needs the correct hole circle to do the divisions and this one does not have it, also there are no spares
Only option is to machine the bit where the drive shaft fits, then make an adaptor to fix the stub axle to the small dividing head that does have the correct hole circles !
I need 2 turns and 2 holes on a 19 hole circle to get the divisions correct.
Another Saturday at work sorting the drive shaft fixings...
I want to get the damn thing sat on its wheels this year so it looks more like a real car !
Old 04-02-2017, 11:14 PM
  #582
markk
markk's Avatar
You need more clearance inside them 1/4 shafts for the balls in the lobro to move into on full droop
Mark V8 (05-02-2017)
Old 05-02-2017, 08:43 AM
  #583
Mark V8
Mark V8's Avatar
Thanks, I'll double check the clearance.
Didn't know they moved that far out
Old 18-02-2017, 06:49 PM
  #584
Mark V8
Mark V8's Avatar
Another Saturday at work...
Stub axle bolted to adaptor so it fits in dividing head
Form cutter for splines I had to get specially made
This bit took many hours to do the pair and get the size spot on
All done apart from slot for locking tab.
I had enough at this point and buggered off home, the slots can wait for another day
Old 18-02-2017, 06:54 PM
  #585
markk
markk's Avatar
Looks just like mine did, how do you spec the cutter for the mill?
i need to make some splines but have never specced a cutter.
  #586
Caddyshack
Caddyshack's Avatar
Wow is a good word to use here
Mark V8 (18-02-2017)
Old 18-02-2017, 07:18 PM
  #587
Mark V8
Mark V8's Avatar
I tried to figure out the profile and gave up
Sent off the Jag stub axle to CR Tools and they sorted it all out for me
http://www.crtoolsuk.com/cutting-tools-sheffield/
Old 18-02-2017, 07:49 PM
  #588
markk
markk's Avatar
How much was the cutter?
Old 18-02-2017, 09:29 PM
  #589
Mark V8
Mark V8's Avatar
Ł130 + vat
Lot to pay for just making two stub axles !
I just do not like the look of the off the shelf shafts with a UJ one end and CV joint the other and after watching this vid I would be even more wary...
Old 18-02-2017, 10:26 PM
  #590
markk
markk's Avatar
I agree, mine back in the late 1990s
Back in 1998
Old 06-03-2017, 08:17 AM
  #591
niall_aus
niall_aus's Avatar
got enough space to get the side carrier bolts in ?
Old 06-03-2017, 05:54 PM
  #592
Mark V8
Mark V8's Avatar
The bolts have to be fitted before shaft goes in carrier.
Added some more clearance for inside of joint.
If I push the shaft in as far as it will go I still get a witness mark from the grease - fingers crossed there is enough clearance !
Old 06-03-2017, 06:22 PM
  #593
3i Jim
3i Jim's Avatar
That's some nice engineering going on there.
Old 06-03-2017, 07:07 PM
  #594
fatboy billy
fatboy billy's Avatar
That engineering work really is stunning.
Must be a great feeling being able to crack open all the nos bits and bolting them on
Old 06-03-2017, 08:34 PM
  #595
Mark V8
Mark V8's Avatar
Thanks, I've been hoarding new old stock for years !
Old 13-05-2017, 04:51 PM
  #596
Mark V8
Mark V8's Avatar
Cleaning bits in citric acid, stuff works wonders and cleans off old zinc plate as well as rust.
Dried and wire brushed before going in polishing gadget.
All gone for plating now. should be back this week.
Not sure if my rear arches are going to like the 235 rear tyres
Spent the day getting covered in crap cleaning the rear diff up.
Hoping to get some epoxy on it next weekend if the weather is dry before it goes off for rebuild.
Old 14-05-2017, 04:01 PM
  #597
costina
costina's Avatar
Looking good Mark. I do a similar process with the bolts prior to plating.
Soak in deox C
Dry off and wire wheel on the bench grinder
Some parts get soda blasted at work and then plating.
Gives and nice even result.
I would have epoxyed the diff that day by next week it might be a little ginger........
Old 14-05-2017, 04:34 PM
  #598
Mark V8
Mark V8's Avatar
Went down the shed to check this morning and rust had started coming out of the pores / pits in the surface of the cast iron
Attacked it with Kurust all over
I'll wire wheel it all again and with luck the Kurust will have stopped the leaching !
Old 14-05-2017, 06:01 PM
  #599
costina
costina's Avatar
I was going to suggest that its the same with hubs water pumps etc.......
Should be good to go
Old 27-05-2017, 05:32 PM
  #600
Mark V8
Mark V8's Avatar
Wire wheeled the diff back to bare metal again and sprayed it with epoxy.
Took it over to a Jag axle specialist on Mersea island for check over / rebuild - going to take 5 to 6 weeks as the guy is really busy.
Got the beam, trailing arms and drive shafts powder coated
Loads of zinc plating, got the platers to mask off parts that would cause issues with bearing fit.
Spent the afternoon assembling drive shafts, buggered up one of the stainless gaiter clips and gave up until I get some more !
Quick Reply: V8 Sierra 2WD
