PassionFord
Register Forgot Password?
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 12-06-2009, 10:27 PM   #41
hitchwest
Trader Score: (2)
hitchwest is an unknown quantity at this point
lookin good mate
hitchwest is offline   Reply With Quote
Old 14-06-2009, 05:55 AM   #42
LINCOLN
Trader Score: (1)
LINCOLN is an unknown quantity at this point
Did a bit more painting - Metal Cast in smoke colour.
I think it suits the carbon stuff I have and am going to do all the tanks as well.
Started prelimary design for electrics - going to create some junction boxes and such under dash, rear and front junction boxes with spring cage terminals.
New looms.
Pectel and Motec power distribution module - this replaces all fuses and relays. Speaks Can bus to ecu and dash and has 30 outputs (8 x 20A) and 16 inputs. Completely programmable so need to think of a few things for it to do (eg. fan control, no ignition till oil pressure on crank, fuel pump check on startup etc).
Switch boxes and motec shift light. Use the honeywell mil spec toggles and piezo led pushbuttons. The shift lift in Can bus and each led is individually programmable for brightness and colour (think there is 8 colours).
And dash (it is a bit dusty).
Motec SDL dash - 16 analogue in, can bus, rs232 to pectel, 4 digital in, 4 digital out (no pwm but can do 2d/3d tables), lambda, logging, backlit.
LINCOLN is offline   Reply With Quote
Old 03-07-2009, 12:54 AM   #43
LINCOLN
Trader Score: (1)
Mounted the seats - this was a real pain as the Sierra has a cross member that gets in the way.
I had to trim the seat bracket to get the front of the seat to sit in front on the crossmember but still allow the seat to go low enough for good ground clearance. Maybe it is just the seat I chose though? It is quite a wide seat (for my mega ass) and needed the high sides so the side intrusion bar could still be legally mounted high (it must be lower than the seat).
Old 03-07-2009, 03:51 AM   #44
rudeboy
rudeboy's Avatar
Trader Score: (2)
rudeboy is an unknown quantity at this point
Awesome Linc
I haven't had a good look around the site for a long time (due to new family member and house renos) ... so I'm glad I stumbled into your thread. Its good to see some photos of your hard work ... well done
Look forward to seeing the damage in person!
Congratulations on your baby mate ... I hope all are in good health.
__________________
Moser
my Moonstone 3 Door ...
http://www.passionford.com/forum/viewtopic.php?t=296926
rudeboy is offline   Reply With Quote
Old 03-07-2009, 05:42 AM   #45
fezzajsy
Trader Score: (9)
fezzajsy is an unknown quantity at this point
Send a message via MSN to fezzajsy Send a message via Yahoo to fezzajsy
nice one
fezzajsy is offline   Reply With Quote
Old 04-07-2009, 12:30 PM   #46
RONNIE AMIS
RONNIE AMIS's Avatar
Trader Score: (16)
RONNIE AMIS is on a distinguished road
looking good mate
RONNIE AMIS is offline   Reply With Quote
Old 04-07-2009, 12:38 PM   #47
J1mbo
B1mbo
J1mbo's Avatar
Trader Score: (1)
J1mbo is an unknown quantity at this point
Send a message via MSN to J1mbo
very cool project and some lovely bits going on it keep the pics coming
__________________
mt-motorsport.com
J1mbo is offline   Reply With Quote
Old 04-07-2009, 02:11 PM   #48
Zetecfiesta
Trader Score: (0)
Zetecfiesta is an unknown quantity at this point
Send a message via MSN to Zetecfiesta
looks very good!!
Zetecfiesta is offline   Reply With Quote
Old 19-07-2009, 11:57 PM   #49
LINCOLN
Trader Score: (1)
Thanks for the words everyone - Tristan - congrats mate and come have a beer any weekend I am working on the car (in Thomastown).
FINALLY finished the roll cage on Saturday
Harness bars and diff mount
Side intrusion.
And front struts.
Old 20-07-2009, 12:19 AM   #50
RONNIE AMIS
Trader Score: (16)
wow!! very nice mate
Old 02-11-2009, 09:54 AM   #51
LINCOLN
Trader Score: (1)
Mounted the dry sump pump. Made this so it's low and forward so I could fit the power steering pump to the rear of the dry sump pump. Ended up struggling so will have to buy a group a style engine mount kit with straight arms.
Had to machine deeply into the standard power steering mounting to get the pump in close.
Power take off to mount power steering pump. Going to use a HD KSE pump as it is only 73mm thick.
Spigoted an adaptor onto the aux pulley driven by 3 solid dowells. Got a 50% crank pulley set and a %54 crank pulley set to try.
Engine is close. Have done the mountune oil squirters, deck height, solid lifters, cc and compression ratio and valve reliefs.
Got 7.4:1 with little piston machining so pretty happy.
Old 29-12-2009, 06:04 AM   #52
LINCOLN
Trader Score: (1)
Been sorting a few things as on holiday - merry christmas to me!!!
Hollinger 6 speed with load cell shifter. Trying to figure out some mounts.
Doing some work this week on it so will keep you posted.
MERRY CHRISTMAS FOLKS.
Old 29-12-2009, 06:35 AM   #53
Vic
Trader Score: (0)
Vic is an unknown quantity at this point
whoa! looks the nuts mate. sequential?
oh and spoke to scott re widebands.. and he says you cant go past the PLM.. argh... can you tell me exactly how much it is again?
Vic is offline   Reply With Quote
Old 29-12-2009, 07:22 AM   #54
badnews
badnews's Avatar
Trader Score: (0)
badnews is an unknown quantity at this point
looking good matey it will be an awsome car when finished
badnews is offline   Reply With Quote
Old 29-12-2009, 08:28 AM   #55
boothy
Trader Score: (14)
boothy is on a distinguished road
NICE
boothy is offline   Reply With Quote
Old 29-12-2009, 08:29 AM   #56
Leslie DG
still d r ift
Leslie DG's Avatar
Trader Score: (0)
Leslie DG is on a distinguished road
sierras all around the world, just love this project like a few others.
quality work m8, keep it going.
Leslie DG is offline   Reply With Quote
Old 29-12-2009, 10:17 AM   #57
LINCOLN
Trader Score: (1)
Will check but I think it was $1100 incl the NTK sensor - will check current pricing.
Sadly no sequential but that is a blessing in disguise as have heard only the new RD6 gearbox sequential has all the bug fixes. H pattern is nice and short though about 2" 1st to 2nd. Absolutly no class would let me race with a sequential as well.
P.S. - tnt sent today!
Old 29-12-2009, 10:19 AM   #58
LINCOLN
Trader Score: (1)
Quote:
Sorry did not catch up when in Brissy mate - take care and will give you a buzz when in town next.
Old 29-12-2009, 10:19 AM   #59
LINCOLN
Trader Score: (1)
Thanks all comments!
Old 29-12-2009, 10:26 AM   #60
Vic
Trader Score: (0)
cool mate just sms me when you find out. i may not need the sensor but let me know the price for no sensor, ntk and the bosch
yeah, i could only imagine the uproar from the old school fraternity if they found out if you had a seqential!
oh.. just fixing you up online right now for the tnt stuff!
Old 29-12-2009, 10:47 AM   #61
COLEYST200
COLEYST200's Avatar
Trader Score: (3)
COLEYST200 is an unknown quantity at this point
ian cole
looking good mate keep up the good work
__________________
Birmingham group
Click here to take a look at my three door project.
COLEYST200 is offline   Reply With Quote
Old 29-12-2009, 11:13 AM   #62
Themistoklis
Themistoklis's Avatar
Trader Score: (0)
Themistoklis is on a distinguished road
Themistoklis Orkopoulos
Send a message via MSN to Themistoklis
Quote:
Originally Posted by ital_cossie View Post
top!!!
waiti to see more photos!!!
+10000
Themistoklis is offline   Reply With Quote
Old 29-12-2009, 01:40 PM   #63
james kiely
Trader Score: (3)
james kiely is on a distinguished road
wow that is one awesome cossie your building lincoln
cheers james
__________________
cheers james
james kiely is offline   Reply With Quote
Old 10-01-2010, 01:30 AM   #64
philram
Mulechild
philram's Avatar
Trader Score: (3)
philram is an unknown quantity at this point
looks great mate.. pm coming your way..
philram is offline   Reply With Quote
Old 10-01-2010, 12:06 PM   #65
adrian73
Trader Score: (0)
adrian73 is on a distinguished road
what about the rear suspension?
adrian73 is offline   Reply With Quote
Old 12-01-2010, 09:34 PM   #66
LINCOLN
Trader Score: (1)
Quote:
What do you want to know - modded 6 degree beam, leda coilovers with 8.8 diff. Not sure which ARB yet - Tony at TCS has a good GpA solution but container has left so not got it.
Jig to mount diff.
Hole for new fuel tank (dont ask yet as the lasercutters fucked up big time and it is a sore point) - but will be a nice sumped tank without the need for a swirl pot. Something along the line of this;
Also did a fibreglass infill for the sunroof panel going to get is carbon wrapped. Could take a mould off it if anyone wants one?
And the master tig welder "all tuckered out"
Old 12-01-2010, 09:43 PM   #67
cossiejsy
cossiejsy's Avatar
Trader Score: (0)
cossiejsy is an unknown quantity at this point
Send a message via MSN to cossiejsy Send a message via Skype™ to cossiejsy
coming along nice
__________________
Dont like my drivin then stop watchin me
Jersey Rs Owners Club
member of the daytime pf talk bollocks and random shite club #65
cossiejsy is offline   Reply With Quote
Old 12-01-2010, 10:43 PM   #68
andy escos
Capt Chaos
andy escos's Avatar
Trader Score: (1)
andy escos is on a distinguished road
very nice work
__________________
500+BHP 4X4 ZAKSPEED ESCORT GROUP 5 FULL RESTO, SOON TO LOOK LIKE THIS,,
TAKE A LOOK AT MY GROUP 5 ZAKSPEED ESCORT REPLICA RESTORATION
Clicky
andy escos is offline   Reply With Quote
Old 12-01-2010, 10:45 PM   #69
ital_cossie
Trader Score: (2)
ital_cossie is an unknown quantity at this point
wait to see the diff fitted!!! keep up with updates!!! and photos!!!
ital_cossie is offline   Reply With Quote
Old 20-02-2010, 10:09 AM   #70
LINCOLN
Trader Score: (1)
Only a small update as have been away for work for basically a month.
The RS500 guys are going to hate me but i just love the matt black with the stainless screws.
Amd beefed up the coilover trailing arms brackets.
Old 20-02-2010, 10:28 AM   #71
Roosie
500bhp Cosworth in making
Roosie's Avatar
Trader Score: (7)
Roosie is an unknown quantity at this point
Send a message via MSN to Roosie
Hi Lincs
looking good this is like my 3door with everything you have done.
have you fitted your balance bar yet on your compbrake pedal box as i have problems with it fitting straight. cheers
Roosie is offline   Reply With Quote
Old 20-02-2010, 10:39 AM   #72
LINCOLN
Trader Score: (1)
No mate - will do ASAP and let you know.
Old 20-02-2010, 10:49 AM   #73
cossiestu
Trader Score: (0)
cossiestu is an unknown quantity at this point
Looks really good mate, cant wait to see more!!
__________________
cossiestu is offline   Reply With Quote
Old 20-02-2010, 10:56 AM   #74
Gav Diamond
Gav Diamond's Avatar
Trader Score: (6)
Gav Diamond is on a distinguished road
Looking good mate, keep it up
__________________
Gav Diamond is offline   Reply With Quote
Old 20-02-2010, 10:59 AM   #75
LINCOLN
Trader Score: (1)
Also as the RS500 throttle body I got was bare I have made all the guts for it;
I will get a pic of the little pins and bearings - cry - might make it DBW so it can match revs on downshift.
Old 20-02-2010, 11:02 AM   #76
fezzajsy
Trader Score: (9)
Old 20-02-2010, 11:14 AM   #77
PAUL_SHEP
PAUL_SHEP's Avatar
Trader Score: (0)
PAUL_SHEP is an unknown quantity at this point
Fair play fella, you got some skills. Makes it all the better that you are doing everything yourself. Keep the pictures coming, ps did you ever sell that djr sump?
__________________
PS3 ID = PAUL_SHEP
"If the only tool you have is a hammer, you tend to see every problem as a nail."
http://passionford.com/forum/restora...-cosworth.html
PAUL_SHEP is offline   Reply With Quote
Old 20-02-2010, 11:17 AM   #78
LINCOLN
Trader Score: (1)
Quote:
Yes mate - just last week.
Thanks for all the comments.
Not all my skills but sometimes it is not what you know...
Old 20-02-2010, 12:20 PM   #79
xHayleyx
xHayleyx's Avatar
Trader Score: (0)
xHayleyx is on a distinguished road
wow i have loved reading this thread so far..
cant wait to see the end result
top work!
xHayleyx is offline   Reply With Quote
Old 20-02-2010, 05:46 PM   #80
whitey
whitey's Avatar
Trader Score: (0)
whitey is an unknown quantity at this point
Nice work there fella its gonna be a weapon
__________________
gsmotosport 07940181847
whitey is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
