PassionFord
Go Back   PassionFord > Ford car Forums listed by Model. > Other Marques
Register Forgot Password?
Other Marques Use this section for any non Ford marques.
Welcome to Passion Ford!
Welcome to Passion Ford.
submit to reddit
Old 02-09-2005, 08:00 PM   #1
JsTurbo
Trader Score: (0)
JsTurbo is an unknown quantity at this point
Default Help!!!, Prob with my escort 1.8 Si mk6
Hello everyone.
Right to the point * *lols.
I just got this car a couple of months ago, its a escort mk6 1.8 Si, 115bhp version.
When i accelerate up hills or when i drive the car hard just the length of a road, when i come to brake and dip the clutch the revs will stick at 3k rpm. They will only come down once i bring the clutch up so it bites and then it will calm down. But as soon as i drive again at say 2k rpm same again when i dip the clutch the revs will creap up on there own to the 3k mark. * * * * Whats wrong!!!!!!!, this only happens when the caris hot and when i have driven hard, but this should not happen still.
2) aslo when i drive at 2k rpm or when the revs drop past 2 rpm there is a rattle coming from under the car. Maybe the cat. bt dunno. Im not loosing any performance and as soon as the car is over 2k rpm there is no noises at all.
If anyone can help i would appreciate.
Thank you,
James * * *
JsTurbo is offline   Reply With Quote
Old 03-09-2005, 08:13 AM   #2
Paddy
Paddy's Avatar
Trader Score: (0)
Paddy is an unknown quantity at this point
The unhappy revs sounds like a sticky throttle or a potentiometer thats on the way out *
As for the vibration, without listening to it, it's impossible to tell could be anything although exhuast clamps like to come loose or spin round so the bolt ends are vibrating against something *
__________________
Paddy is offline   Reply With Quote
Old 03-09-2005, 10:24 AM   #3
JsTurbo
Trader Score: (0)
thanks mate,
I will havea look at it. Cheers,
Old 03-09-2005, 03:38 PM   #4
BM08
BM08's Avatar
Trader Score: (0)
BM08 is on a distinguished road
1st problem is either idle control vavle or throttle position sensor, i had same problem with my escort gti, a new throttle sensor sorted this out
BM08 is offline   Reply With Quote
Old 04-09-2005, 09:51 AM   #5
Paddy
Paddy's Avatar
Trader Score: (0)
Quote:
There ya go was trying to think of the modern term for potentiometer that would be in the haynes manual or the muppets at the motor factors/ford parts would know *
I'm getting old *
__________________
Old 04-09-2005, 02:53 PM   #6
JsTurbo
Trader Score: (0)
Thanks people,
I will have a look and let you all know,
Old 04-09-2005, 05:02 PM   #7
Moondust_crust
Trader Score: (0)
Moondust_crust is an unknown quantity at this point
does this on mine mate exactly as you have said , ive got a 1.6 si, although my *revs havent stuck for over a month now , the rattle you hear is the scuff plate on the bottom of the cat , they tend to rattle around a bit. hope this helps, cheers mark.
__________________
Very Nice Very Tastefull.......
Moondust_crust is offline   Reply With Quote
Old 06-10-2005, 10:40 PM   #8
Turbo Pez
Trader Score: (0)
Turbo Pez is an unknown quantity at this point
Send a message via MSN to Turbo Pez
Does it on mine (same car 115ps si), it seems to come and go, mainly does it when cold! its done it for the 2 years i've had mine, still runs fine so ain't gonna fix it * ,
p.s.
if your clutch goes, get a garage to do it coz its a c*nt of a job, just finished doing mine today, found it easyer taking the engine out my turbo!! * *
Turbo Pez is offline   Reply With Quote
Old 03-12-2005, 05:02 PM   #9
Toniboy
Trader Score: (0)
Toniboy is an unknown quantity at this point
A up,
iv'e got gti and just started doing it on mine. changed the air flow senser but made problem worse, did you change the thottle position senser-and did it work,
thanks T,
Toniboy is offline   Reply With Quote
Old 11-01-2006, 01:51 PM   #10
andy_st200
Trader Score: (0)
andy_st200 is an unknown quantity at this point
its nearly always the idle control valve their shit on the mk6 and go all the time
andy_st200 is offline   Reply With Quote
Old 19-01-2006, 02:12 PM   #11
mart.rs
Trader Score: (0)
mart.rs is an unknown quantity at this point
ive got the same problem on mine too,ive had the car for just under 3 weeks,can be a little annoying!!! mines an 1800 si n reg i love it,except this idling problem!!!!
mart.rs is offline   Reply With Quote
Old 06-02-2006, 10:24 AM   #12
nick_GTI
Trader Score: (0)
nick_GTI is an unknown quantity at this point
Send a message via MSN to nick_GTI
Deffo idle control valve my GTi was doing exactly the same thing. Took the valve of cleaned it out, coated it with good old WD40 then reset ecu. Make sure you reset ecu cus mine ran a bag of sh*t till i reset it.
nick_GTI is offline   Reply With Quote
Old 09-02-2006, 10:19 AM   #13
Toniboy
Trader Score: (0)
hi mate, iv,e got a gti and mine started doing the some thing about 4 mounth ago. 3000k plus rattle under the car. i had the mas air flow changed plus spayed the lot with wd40, but did not help in anyway. i disconnected the battery to reset the ecu and it seemed to do the trick the revs went back to normal. but when the car got hot it started to lose power until i put the accelorater to the floor and then it would put ya back in ya seat. the car is in at FORD at the moment for the 6th time for the same thing. i dont no if they no what they are doing?. hopefully yours is something simple. the cars due back any day now so i'll get back in touch with ya and let ya know what the problem was, thats if they fix it.
Toniboy
Old 20-02-2006, 11:40 AM   #14
Turbo Pez
Trader Score: (0)
I just bought a new idle control valve of ebay for mine mk6 115ps, seller called the-ford-shop, sells them all the time, I did clean mine old 1 and did make it beta for a few months, but started doing it again!!
Fitted the new 1 and it idle at 2500rpm, so i disconnected the battery for a couple of hours to reset the ecu, reconnected the battery, started it up, idles perfecty, sat a 1500rpm on cold start, took it for a spin, now sits just below a grand!!!
New valve cost me 48.98 including p+p, from the seller "the-ford-shop" there always seller them!!
__________________
Nissan Quasqai Daily Drive - WTF
Mk6 Escort Daily Drive - SOLD
RS turbo Restro - Ended....
3 Bed House Restro - Started
Old 27-02-2006, 01:22 PM   #15
silencer
Trader Score: (0)
silencer is an unknown quantity at this point
so this could be a really stupid question but the idle control valve where bouts is it and is it an easy job to do thanx..
silencer is offline   Reply With Quote
Old 03-03-2006, 10:32 AM   #16
Turbo Pez
Trader Score: (0)
Quote:
Its stuck on the inlet manifold, on the side close to the engine, only 2 bolts, but a complete nitemare to get to! best to do when engine cold as well!!!
__________________
Old 07-01-2010, 03:06 PM   #17
muellergb
Trader Score: (0)
muellergb is on a distinguished road
Hello there,
Be gentle with me pls.I've just joined this forum.I've got a 1997 1800si (115 bhp) and I'd like to know the clutch drive plate diameter,is it 210 or 220 mm.I need a new clutch.Where can I go for best price.Many thanks in advance.
muellergb is offline   Reply With Quote
Old 09-01-2010, 11:59 PM   #18
MrF
Trader Score: (0)
MrF is on a distinguished road
The rattle also could be the heat shield beside the fuel tank, mine had ripped metal and was flapping around and needed to be resecured, after that...no more noise
MrF is offline   Reply With Quote
PassionFord
Ford Focus
Paid Advertisement
submit to reddit
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
