Music & Car Audio Chat Most of your cars have a great sound system and you love music yeah? Discuss these things here...
amp power switch
Old 28-01-2016, 07:17 PM
kc87
kc87's Avatar
Default amp power switch
Hi just a quick question.
I am wiring up an amp and was wondering could i use a spare window demister switch as a on off button and how would i go about this? I have a 55plate focus.
Thanks
Old 28-01-2016, 07:41 PM
costina
Live long and prosper!!
costina's Avatar
Thanks
Amp remote is on most headunits and blue in colour. When you turn on head unit this will be 12volts and connects to amp switch+.
Hope this helps
Old 28-01-2016, 07:45 PM
kc87
kc87's Avatar
Hope this helps
Thanks i get that. But can i run the amp remote lead to the spare window demister switch and use that as a on off switch to turn the amp off wen i dont want it on?
Old 28-01-2016, 07:58 PM
costina
costina's Avatar
Yes that will be fine.
Old 28-01-2016, 08:06 PM
kc87
kc87's Avatar
Great now how do i do that?
There is 5 wires that come out of the plug for it.
Orange and white
Green and white
Black and white x3
Which wires are which ie power on n off?? So i no which wire to connect the amp remote leads to.
Any help would be great thanks
Old 28-01-2016, 08:10 PM
costina
costina's Avatar
Orange and white
Green and white
Black and white x3
Pics would be better and what amp?
Old 28-01-2016, 08:19 PM
kc87
kc87's Avatar
EDGE ED7300 2 Channel Stereo Amp
Heres the switch wiring
Old 28-01-2016, 08:26 PM
alexno1dj
alexno1dj's Avatar
I did exactly this with a redundant beacon switch on an escort van, used it to remotely switch 3 different amps. From what I recall i ended up using a multi meter as you need to find switched live.
Old 28-01-2016, 08:27 PM
costina
costina's Avatar
You will have to do a google search on that amp.
Old 28-01-2016, 08:30 PM
kc87
kc87's Avatar
More details would be good thanks.
Old 28-01-2016, 08:31 PM
kc87
kc87's Avatar
The amp is fine i jus need to know which wire to run the amo remote lead to from the head unit and back out the switch to the amp
alexno1dj
alexno1dj's Avatar
Amp make/model is irrelevant, as long as it has 12v remote input it will work. Remember to have separate feed for main amp power direct from battery
Old 28-01-2016, 08:34 PM
alexno1dj
alexno1dj's Avatar
You wont need the remote from the head unit, you just want to use the switch to provide 12v on/off to turn amp on/off. Therefore all you need to do is determine which wire is the switched 12v supply for demister and connect instead to amp remote input
Old 28-01-2016, 08:36 PM
You gonna need a multi meter to check which wires you can use. I would do a resistance check across the wires then work the switch to see which wires you can use.
Old 28-01-2016, 08:41 PM
kc87
kc87's Avatar
I have the main power feed for the amp seperate.
All your help is appreciated thanks.
From the pic i posted can you tell which wire is which so i can have a head start lol thanks.
All i want the switch to do is turn the amp on and off
Old 28-01-2016, 08:43 PM
kc87
kc87's Avatar
I shall give that a go thanks
Old 28-01-2016, 08:45 PM
No bother if you lived closer i would offer to help you with it.
Old 28-01-2016, 09:47 PM
alexno1dj
alexno1dj's Avatar
Im sorry, without using a multi meter I wouldnt know from memory. But yes what you are looking for is +12v from multi meter when you turn switch on. It may take a while to suss it out, trial and error. Then when you have found correct one, add a length of wire and run to amp/s
Old 10-02-2016, 01:33 PM
salsheikh
salsheikh's Avatar
just get a simple on/off switch from maplins and use that instead of this faffing about. plus you can hide it if you wish. mine is in the centre console - replaced the cig lighter port.
Rod-Tarry
Computers, Consoles and I.T.
07-04-2017 11:42 PM
p.laver
Ford Fiesta
24-02-2016 07:34 PM
lewisjackson96
Fiesta ST
27-01-2016 08:16 AM
Gadget
25-01-2016 05:11 PM
Ellsa
05-01-2016 02:17 PM
Quick Reply: amp power switch
