Dry bearing sound
Old 20-10-2016, 11:54 PM
LovingMyST
LovingMyST's Avatar
Default Dry bearing sound
Fellow ST owners
I recently purchased a 2015 ST3 with 22,000 miles on the clock. Now having owned this car now for 4 wks I have noticed what can only be described as a dry bearing noise coming from the drivers side of the engine that is constant whilst the engine is running and seems to get louder when driving the car!...I have since put it into Ford to diagnose to which they have replaced some idleing tensioner if that makes sense.....yet the noise is still there!..They are adamant this is a common noise to which I have nothing to worry about.....not happy with the answer I got I have since sought a second opinion at Keith Motors another Ford dealership. One of the mechanics had made a comment saying he had seen similar questions being asked on other Ford forums to which no answer was available. can I ask if anyone on here has had/have/heard the noise I am describing and if so have you managed to find the source and what was required to rectify?.....any help/advise is greatly appreciated
Thanks in advance
Old 21-10-2016, 12:01 AM
RSmark84
RSmark84's Avatar
Could be the air-con pulley. It happened on my Evo.
Try something like this to see if the noise goes away.
https://www.amazon.co.uk/CarPlan-WBU.../dp/B00499DFNM
Obviously its not a permanent fix. spray on each 'component' until you find what one it is. Its how I found out my air con pulley was at fault.
Old 21-10-2016, 05:17 AM
Its under warranty tale it back to the dealer.
Old 21-10-2016, 05:39 AM
LovingMyST
LovingMyST's Avatar
Glenn/RSmark84
Thanks for your replies
Car is booked in next month into a ford garage to sort under warranty. Was just looking to see if someone else had/has experienced the same noise to which I could give the mechanics a head start on where to look??
Old 21-10-2016, 07:19 AM
stevos
stevos's Avatar
Can't help mate but keep us updated as I'm looking at buying an estate version next year.
Old 21-10-2016, 07:52 AM
LovingMyST
LovingMyST's Avatar
Will do
Old 21-10-2016, 11:32 AM
gcfcos
gcfcos's Avatar
All they need to do is get a mechanics stephascope on it (that prob wrong spelling)
LovingMyST (21-10-2016)
Old 22-10-2016, 06:41 AM
Or a long screw driver lol
Old 22-10-2016, 05:53 PM
gcfcos
gcfcos's Avatar
Problem is from a lot of the "technicians" as their called now at dealers, anything that strays from the norm their stumped.
Old 22-10-2016, 07:59 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
Focus or fiesta?
I have a 62'plate focus st and took it to ford back in january with noise coming from the engine, belt side. The said they put talcum powder on the pulleys and it stopped. Well the noise was exactly the same as it was before...
The injectors are very noisy on these engines and it could be that making the noise?
Old 22-10-2016, 08:08 PM
LovingMyST
LovingMyST's Avatar
When it was Ford they used an ext bar from a socket set and placed it on the block to which the noise was clearly heard, however after having my car for 2 days and replacing something completely different like you the noise is still there!....hence booked into another Ford garage hoping they will rectify.........
Old 22-10-2016, 10:58 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
Tbh if you google it as i did, i think you will find its quite 'normal' in a sense.
I done the whole screwdriver thing and concluded it was the injectors.
Old 23-10-2016, 03:00 AM
LovingMyST
LovingMyST's Avatar
I have tried, and the injectors tend to make a ticking noise....I have 2 work colleagues who also have 65 plate ST's one with just over 2000 miles(Sunday car) and the other just over 7000 miles....neither one have this noise....that could be down to the mileage difference between there's and mine....
Old 23-10-2016, 02:13 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
Mine is on 38k now, had it since 26k and its been the same the whole time.
I have not heard another in person to compare it to either.
If you find out what it is let me know!
Old 24-10-2016, 08:03 PM
LovingMyST
LovingMyST's Avatar
Will do
Old 26-10-2016, 08:35 PM
lesley7
lesley7's Avatar
Originally Posted by LovingMyST
Will do
just take the belts of and start it for a min if the noise goes it wont be to hard to find
Old 26-10-2016, 08:37 PM
Adam-M
Adam-M's Avatar
Will it continue to run if the alternator isn't spinning? Thought the battery was only used to start the car then the alternator takes over
Old 28-10-2016, 05:04 PM
LovingMyST
LovingMyST's Avatar
because the car is still under manufacturers warranty I personally don't want to tinker with it.....When I drop it off on the 28th Nov I will mention that I have posted this issue on a forum and let them know of any comments that could assist them in resolving this issue......again thanks to all to whom have taken the time in replying....
Old 28-10-2016, 05:14 PM
gcfcos
gcfcos's Avatar
I see your in Bournemouth too as u mentioned Keith motors!
Old 28-10-2016, 05:30 PM
LovingMyST
LovingMyST's Avatar
Yes mate...live not far from castle point
