Mondeo K3 zetec replaced ecu HELP. Please anyone
Ok, paid over the top for a 01 Mk3, missed fired etc at 2000 rpm and above, a google search leaded to coils, which leaded to a bit of a test and find coil pack in car OK, had been replaced (to the square plug type)
Ok -- ECU looking like its blown.
Got another ECU from affordable parts, at great cost, fitted.
And of coarse . fords PATS immobiliser kicked in.
Help, please anyone... just want to get this up and running cheaply, (I'm 100 miles from nearest ford dealership.
Can ??? the two ecu's been run together, so to speak , eg -- wireing up so that the original ecu takes care of the PATS immobiliser, and the 2nd hand ecu that I bought runs the motor/car ???
could this be done ??
thank you
thank you
As said above, you need the transponder from around the ignition barrel and chip from the key. The mk3 uses the same type of key. Local scrappies are pretty plentiful for the mk3 now as they are at the bottom of their value so hopefully it should be fairly easy to find one.
mondeo ecu
car does nothing but bring up dash lights.
ecu and key
Plug and play
But haven't yet find a scrapie that sells the matching key to ecu.
but thanks
Try searching for them on eBay. Rather than searching for an ecu search for mondeo breaking etc and message the seller asking how much for the ecu, key and transponder etc
thank you
thank you
Google search
but its a bit of a case of limit funds and tools/gear to test.
Still got this problem, replaced ECU/Key/ and another computer box, plus coils/leads bought as a package deal.
Same problem, it, may, may be a little better ?? Eg it'll Rev a bit higher....
Yes you are right.
