used 4x4 front brake prices
How much would I expect to pay for a second hand standard brake set up for a 4x4 cos.Mine has 4 pots so I want to put standards back on
Discs pads calipers carriers
RetroTed (25-04-2016)
What size wheels do you need for these callipers? I have standard 4x4 on mine so could do a deal if they fit under my 16 inch comps
It will completely depend on the design of the wheel. I have 17" Hockenheims which don't fit these brakes on my 4x4, but 16" wheels with a lot of clearance should be able to fit.
I assume it's this kit: http://https://www.apracing.com/prod...5200-1000.aspx
So you can use the template from AP to check the clearance in your wheel: https://www.apracing.com/drawings/P16011.pdf
I have tried the template and it doesn't fit which is a shame. I tried it with 7X16 Comp TH ET25 and 8X16 ET25.
155lee
28-04-2016 11:18 AM
Caddyshack
20-04-2016 07:50 AM
uk-doctor
19-04-2016 02:14 PM
