cosworth 4x4 6 speed syncro gear kit
pectelboy (27-06-2015)
Do tell more. I assume it is a bigger casing to house the bigger, stronger gears plus the extra one?
Will it be close ratio with the same top speed?
Is it std ratio then, I thought most cosies were over geared for about 180mph theoretical top speed (if they had the power to pull it)
oem Top gear ratio seems about right for aussie highway speeds for escos on 225/40-18's.
I like the short 1st for crawling when stuck with traffic or getting off the mark for trackday stuff.
I find for some trackday stuff a ratio between the oem 1st & 2nd would be ideal.
Obviously a car for all purposes is a compromise.
An extra slow shifting cog may not make the car quicker, so shift speed would need to improve by 20% to make up for another gear change.
Will the ratios be customisable romain? A long first for launching would be good
Odd post to not add any info to the thread? Sounds like marketing bs when you get no replies...
Anutternutter
21-08-2015 06:07 PM
charliecosworth
19-08-2015 02:00 PM
