Performance/ quarter mile times of cossies with efr turbos...
Old 20-05-2015, 05:55 PM
  #201
tutuur
tutuur's Avatar
The fact the americans want low pressure actuator is probably because of the Honda boys running low boost with them. Geoff mentions this to everyone buying an EFR too so trust Mark!
Old 20-05-2015, 09:39 PM
  #202
turbotrev
turbotrev's Avatar
Any news on yours yet crazycage??
Cheers Paul
Old 21-05-2015, 06:25 AM
  #203
crazycage
crazycage's Avatar
Cheers Paul
Yes I had it back on the dyno last Friday , the rear cank oil seal let go and killed the paddle plate . Turbo is Awsome tho all the torque was in before 4k .it's all sorted now and going back on tomorrow night
turbotrev (23-05-2015)
Old 21-05-2015, 02:06 PM
  #204
smiley
smiley's Avatar
will be good to hear your views once youve had time to drive the car mate post back?
Old 21-05-2015, 07:18 PM
  #205
3doorcozmess
3doorcozmess's Avatar
I've bought a 7064 and manifold but I'm going external wastegate I can't wait to get these fitted to my 2wd. after seeing Caddyshack graphs of this turbo on a standard engine I definitely think it's the way to go.
Old 23-05-2015, 07:15 AM
  #206
3doorcozmess
Cheers Paul
Any news crazy
Old 23-05-2015, 04:08 PM
  #207
crazycage
crazycage's Avatar
Originally Posted by 3doorcozmess
Any news crazy
Destroyed a second clutch ,time for a twin plate
Old 23-05-2015, 04:48 PM
  #208
Mark Shead
Mark Shead's Avatar
Lol that means it's got some grunt
Mark
Old 23-05-2015, 05:16 PM
  #209
3doorcozmess
Doh, did you get to power run the car
Old 23-05-2015, 05:58 PM
  #210
crazycage
crazycage's Avatar
Yes but it means nothing ,clutch wouldn't take anymore than 300ftlb
Old 09-06-2015, 10:10 AM
  #211
Romain 83
Romain 83's Avatar
Default efr7670 1.05
hi,
i permit to show my last test 2 weeks ago with efr7670
it made 572hp and 500lb/ft peak 31psi and hold 28psi
Old 09-06-2015, 10:22 AM
  #212
SHaDoWLanDZ
Boost = life
SHaDoWLanDZ's Avatar
I posted just the same Romain
So edit my post.
Hope on 98ron it will be about 540hp also. But first need to solve the idle map problem.
Old 09-06-2015, 10:42 AM
  #213
turbotrev
turbotrev's Avatar
Nice power!
So that's 572hp on race fuel not pump fuel?
What internal engine mods does that have? ie cams, headwork, pistons, etc?
Cheers Paul
Old 09-06-2015, 10:44 AM
  #214
SHaDoWLanDZ
Boost = life
If the car runs perfect this week i'll make a new topic with some details
572 is on 102ron, it is also pumpfuel as we can fill up here on the dutch/german border with 102ron.
Right now i'm running on 98ron but have small problems with overfueling on idle, Romain needs to fix it and then i go on dyno again
Old 09-06-2015, 12:11 PM
  #215
nixon_2wd
nixon_2wd's Avatar
I just find it weird you don't see many being used on tracks/drag strips etc, or are they......
Cheers Paul
1. They are expensive
2. Tuners don't know them / keep up with time / spend time developing so they rather fit ancient "well-known" turbos.
3. Engine regulations prevent turbos like this from being used in motorsport due to restrictors. Why would you want a turbo designed for use with a restrictor on your non-restricted engine?
Although, I am curious to why we (atleast I haven't) haven't seen titanium turbine wheels in motorsport yet.
The EFR is designed to be as quick as possible without restrictions->what you want.
Also, you need to compare apples with apples.
I think dynoing should be standardized, meaning that an engine should be held steady at 2000rpm (or something similar), then do a clean pull up to the rev limiter. Today, people are getting more aware of the meaning of torque, so tuners "adapt" by increasing the "hold" on their dynapacks to 2500 or even close to 3000rpm, "magically" producing SERIOUSLY amounts of torque as the turbo spools to nearly full boost before the pull is even started, just to get their customers happy (400hp @ 4000rpm). - then when the customer goes to drive it, he will never see that "response".
There are just too many variations going on with dynoing nowadays.
Old 09-06-2015, 05:57 PM
  #216
stevieturbo
C**t
stevieturbo's Avatar
Originally Posted by Romain 83
hi,
Is there a boost trace for that ? It also looks as if it's achieving boost quite high in the rpm ?
Old 09-06-2015, 06:15 PM
  #217
turbotrev
turbotrev's Avatar
I thought that too mate but didn't wanna say anything incase I got shot down....
Peak power at 5500 revs??
Cheers Paul
Old 09-06-2015, 07:13 PM
  #218
turnover
turnover's Avatar
It's probably on a honda Stevie so vtec kicks in around 5k then they take off
Old 09-06-2015, 07:27 PM
  #219
Mark Shead
Mark Shead's Avatar
Cheers Paul
Peak power on his is over 7500rpm.
Mark
Old 09-06-2015, 07:53 PM
  #220
smiley
smiley's Avatar
Great thread this
Old 09-06-2015, 08:27 PM
  #221
The Enigma
The Enigma's Avatar
Mark
When is peak power on a YB running like the 7064 or 7670?
When would expect a 6258 to be at peak power?
Old 09-06-2015, 08:32 PM
  #222
Mark Shead
Mark Shead's Avatar
My spec engines tend to make peak power at 6.5k and on a stock engine with a 6258 I would expec it at 6k
Mark
Old 09-06-2015, 08:52 PM
  #223
The Enigma
The Enigma's Avatar
Mark
Thanks for the reply Mark. I've currently got a T34.63 in my Saph and comparing the graph I have to the ones you posted on page 2 just show what an awesome range the EFR is. My T34 is peaking earlier than the EFR's at about 5.5k but is only making 200 at 4k and 120 at 3.5k!
Cheers Rich
Old 09-06-2015, 10:18 PM
  #224
SHaDoWLanDZ
Boost = life
Indeed 572.9 @ 7650rpm
and about 500lbft @ 5460rpm
Old 09-06-2015, 10:32 PM
  #225
turbotrev
turbotrev's Avatar
Sorry my bad, I meant full boost at 5500 revs, isn't that late for an efr?
I know of gt30's and t34's making full boost earlier than that??
Cheers Paul
Old 09-06-2015, 10:35 PM
  #226
turbotrev
turbotrev's Avatar
Has yours been rolling roaded on the 98 Ron fuel mate?
Cheers Paul
Old 09-06-2015, 10:47 PM
  #227
SHaDoWLanDZ
Boost = life
That is not the fastest spool indeed. I must say in the car it feels more alive or not laggy at all.
Paul, no net yet, having some issues with spark plugs at the moment..
When solved going on dyno with the 98ron fuel asap!
Old 09-06-2015, 10:48 PM
  #228
turbotrev
turbotrev's Avatar
Sounds interesting buddy, best of luck and am looking forward to the results!
Cheers Paul
Old 09-06-2015, 11:07 PM
  #229
SHaDoWLanDZ
Boost = life
Will keep update on this forum
CHeers!
Old 14-06-2015, 04:01 PM
  #230
3doorcozmess
Crazy, shadow any news
Si
Jay, (17-08-2015)
Old 14-06-2015, 07:34 PM
  #231
crazycage
crazycage's Avatar
I ran the car last week at pvs did a pb 11.7@123mph got my new twin plate clutch to fit then back to the dyno to finish mapping .
Old 15-06-2015, 02:54 AM
  #232
SHaDoWLanDZ
Boost = life
Si
Not yet, Oppliger needs to come down for a little tweak in te map, having some probs here.. When solved, going for dyno/performance numbers!
(don't know if anybody on here tested 100kmh-200kmh (60-130?)
With some issues i'm doing low 8seconds.
Should be low 7 when everything is OK
Old 15-06-2015, 06:03 PM
  #233
3doorcozmess
How does the car feel on the efr? Sorry can't remember what turbo you was running to lazy to read back lol.
Si
Old 15-06-2015, 08:48 PM
  #234
crazycage
crazycage's Avatar
How does the car feel on the efr? Sorry can't remember what turbo you was running to lazy to read lol.
Si
I've got the 7064 ,feels really good pulls hard and from low down .its spoiling better than my old gt2871 and doing more power with a lot more still in it
Old 22-06-2015, 07:50 PM
  #235
3doorcozmess
Crazy pull your finger out what's happening
Si
Old 22-06-2015, 08:12 PM
  #236
crazycage
crazycage's Avatar
Si
Cars in bits , building roll cage and new dash
Old 03-07-2015, 11:30 PM
  #237
SierraCos2wd
jesus lives good....
SierraCos2wd's Avatar
This is what my new engine did with gt3582r t4 1.06ar 2bar boost 750nm 665hk @wheels
Old 11-07-2015, 04:02 PM
  #238
1300gt
1300gt's Avatar
Can you fit a efr internal gate type to a standard 2wd manifold with no clearance issues for the cylinder head etc
Old 16-08-2015, 10:18 AM
  #239
The Enigma
The Enigma's Avatar
Stu @ M Developments.
Secondly, as spool is much improved, your torque band should move left as the engines getting bigger, faster, thus giving you more useable torque area UNDER THE GRAPH. As an example, the T34.63 tends to make peak boost on the Dyno, when floored at 2000rpm, by around 4000rpm. An EFR will deliver the same amount of air by around 3500rpm. This is because the EFR turbo requires less energy to rotate it so it rotates up to the required speed faster. for any engine driven in this lower engine speed area, the car WILL be faster than a comparable T series equipped car driven at the same speed in the same gear. IE: 70mph roll on in 5th gear side by.
Which EFR turbo are you referring to when you say "An EFR will deliver the same amount of air by around 3500rpm"? As surely a twin scroll 7064 and a twin scroll 9180 are going to spool at very different times, aren't they?
Old 17-08-2015, 09:03 AM
  #240
PassionFords Creator
Stu @ M Developments's Avatar
Indeed they will... but you may note I quantified that statement as it being against a "Comparable T series" IE: You wouldnt try to directly compare a T34 to a GT35 for example.
Quick Reply: Performance/ quarter mile times of cossies with efr turbos...
