power from a 205 block
Wasn't steve (cossie4i+) making 460dd at the wheels in his xr4i with a 205 block?
Ran 440 on mine for a year or so and no problem, before that it was running 411 for about 5yrs.
I know Dingy and Brom ran 500 and as mentioned Steve is also, depends on YOU personally and how far you want to push it, imo I'd opt for a 200 block of costs allow.
KSA-Cossie (16-11-2014)
Mine is at 470, don't know how it will last as it has only just started at that power.
350+BHP & your block is on the limit of sensible power. More, & you are on borrowed time, the power vs reliability graph drops rapidly over 400 BHP. Yes there will be exceptions but in general every 205 block I have seen over 15 years of Cosworth ownership in 205 form WILL crack at some point, be it bores or headbolt areas. If you are spending on a serious engine the only place to start is a long studded 200 block IMHO, it's just a false economy to do it with anything else.
What if you converted the block to liners? Would that be worth doing or a waste of time?
You could see big power - but for a limited time.
I would say circa 400 is the boundary for a 205.
but there are always exceptions. some will crack before that some can go above and beyond.
Depends on the block, bore size, casting variations etc etc. Then if its bored out, been linered, etc. I even know of a couple that had enough meat in them to be long studded.
Then you get down to how its spec'ed and well its built up. pistons,cr, management and mapping - all go toward how well and how long the engine will perform.
What do you have in mind? or is this just a general question?
I would of installed a 200 block if the previous owner didn't put a brand new 205 block with new pistons in just before I bought it. They have only done 1000miles
It is crazy the amount of opinions that are out there I've heard of some Karl norris builds 400-500 bhp cars are not long studded. Also what cracks the blocks??
that was on a 200 block, the point im making is standard headbolts are fine ime.
ive had a 1mm overbore 205 block crack up the bore but it did lots of miles and abuse at 350 hp first.
I wouldn't be worried about running a 205 at 500 hp on standard headbolts as long as the block isn't overbored and isn't rotted to badly from inside out in the water jackets.
Wanted 400 bhp from mine and I'm building it from scratch, I sold my 205 block as it was .5 and let's face it I want it reliable so I changed it for a 200 block.
On a standard 205 bore I'd have used it for stage 3 350ish bhp but no more although they can do it.
No point long studding for me, waste of time and money as standard bolts are fine for power I need.
Just tune what you have to where you want it, enjoy it, but be prepared for it to let go at some point. Use what you have to have some fun, it owes you nothing. Then in my opinion build a replacement on a long studded 200 block...
...that's what I'm going to do - I'm enjoying the 205 at 415bhp, am NOT going to invest any more cash in trying to make the 205 stronger, I'm just seeing it as a consumable!
WHEN it does go, I will invest in a long studded 200 block build, but for now and until it blows up, I'm having a great time!! Life's too short to worry about it, just drive it!
Ben
Ben
Acac (31-03-2015)
Totally agree with Ben
Cheers Paul
Cheers Paul
Ben
Ben
Just want to know if 480bhp is achievable from a 205 block and has any one done it. I bought my saff last year and want to get good use out of it this summer. I don't want to blow it then have to source a 200 block and swap every thing over yet If it does let go I hope it's at the end of the summer lol.
Cake lover!
I ran 450bhp on a 205 block with a T4 running 2bar for about 4-5years and never killed the block. Infact the block is still sat in the shed at home waiting for a rainy day. i just kept hammering it until something gave out.
Tbh i think its a bit of a lottery on a 205block at 400bhp+ some fail others dont, alot will come down to how good the block was to start with. The 205 block i used had never been over standard power or bore until i had it machined for my uses, the block had been stood for over 10 years without water through it as well.
Interesting discussion about the overbored 205's being weak. My original engine (it was removed in 1995 after the head gasket went and one of the bores got badly scored), was replaced with a 2nd hand short engine and I've only now, 20 years later, got round to having it rebuilt.
The score in the block necessitated a +1mm overbore, with new rings and pistons. I'm not considering massive power, just want a moderate tweak to around 300bhp.
Before the engine came out it had done ~30,000 miles, and has been dry stored for all the time it's been out. I assume I'm safe(ish) at 300bhp, or am I going to be running on borrowed time?
Happily retired
That will not be as good as an old Block that has been heat cycled over time . Stop grasping at Straws either run sub 350 Power or use a 200 Block.
Happily retired
I can only give advice cant force anyone to do anything if they are wise they will listen. The decision on this build is being made on money grounds & that's one thing you don't do when building a YB to be reliable. The suck it & see approach will mean another thread in a years time on a rebuild caused by a 205 cracked block with the comment it ran 450bhp for a whole year . Its another how much Power will a T5 take as they rebuild there 3rd Gearbox.
DOING IT ONCE MEANS DOING IT RIGHT. that's always been my Motto.
Sponsor
This is correct but many are held back by a budget
Yes they seem ok up to 500 but any further is a bit dodgy seen a few crack in half at 550+
Source: http://www.burtonpower.com/cylinder-...pe-sc1209.html
Cosworth YB RS500 thick wall motorsport type
Product Description
A very limited batch of genuine RS500 Cosworth YB motorsport blocks are now available. Machined from original castings, these blocks are stronger than the 4wd 200 block. All blocks are machined to take 6 long studs and are also machined for piston spray jets. Blanking plugs are supplied for applications that do not require the jets. Machined to original bore size and deck height, they also feature billet machined steel main caps. Supplied with oil gallery and water jacket bungs and core plugs. Long stud kit and piston spray jet kit can be supplied at additional cost. Std bore size.
Ford Cosworth YB 16v Turbo
Application: Ford Sierra RS Cosworth 3 door 1986-1987
Ford Sierra Cosworth RS500 1987
Ford Sierra Sapphire RS Cosworth 2wd 1988-1989
Ford Sierra Sapphire RS Cosworth 4wd 1990-1992
Ford Escort RS Cosworth 4wd T34 1992-06/1994
Ford Escort RS Cosworth 4wd T25 06/1994-1996
If you intend building a “bullet proof bottom end” and IF it’s true what is claimed in the product description, I think there is no better block for cossies available – not only for big power cossies.
Does anyone know more about this block/offer?
I'm interested myself ...
How about this one …
Product Description
Product Description
for £3k though surely a linered 200 block would be cheaper and even stronger at this price level for a bare block ?
cossie fan (unluckerly)
I'm going for 650 and was told I don't need oil spray jets with a standard crank. I only need them if I fit a more modern crank with a counter balance on each journal
