Anyone seen any multi plate clutch alignment tooling?
I have a triple plate that all three plates need to be aligned together to get the box on.
When I was running ford splines I have a dummy input shaft I used, now I am using Nissan splines I have no way of accurately aligning the plates.
Is there a tool made that is universal to multi-plates?
Ta
Ta
Almost all American clutches come with a plastic alignment tool.
Or best option is an old input shaft.
Go onto some of the Skyline forums and ask. Someone somewhere will have the plastic tool
Or some of the Skyline guys in the UK are bound to have them knocking about from clutches they have fitted.
Or maybe broken gearboxes.
eg
NZ seller selling most for around $8 each
http://www.fortyone.co.nz/parts/show...nt%20Tool.html
Other places may not list them, but they are available.
eg
cossie fan (unluckerly)
Cheers Stevie,
Ive not bought one yet, but I have just sent them an email to confirm application.
I am good on the lathe, but I don't thing I could cut splines that easily on my Colchester lol
I also have access to a nice turret head Bridgeport and to cut splines like that would take some time lol - possible, but serious time manually.
Cheers Stevie,
I made one
It is easy . Turn material to fit in through the plates
Then run a mig welder up it , then just machine the weld on a mill or lathe to leave a key .
( if you do it on a lathe , put a milling cutter in the chuck and your job in the tool post )
You only need one long spline to line up the plates as the diameter diameter of the bar wil do the rest
This works well as I done this years ago on my clutch plates and all went together first time
As for using the tool post to hold the job this is a old school way which works if you have not got a mill
