Hart / AS inlet support
Old 07-02-2012, 07:09 PM
BRAMMER
BRAMMER's Avatar
Default Hart / AS inlet support
Does the standard Ford support fit the base of this inlet - bracket to engine mount?
http://www.ebay.co.uk/itm/4000511296...84.m1423.l2649
Old 07-02-2012, 07:30 PM
Cossie Sean
big floppy donkey dick
Cossie Sean's Avatar
Good question, i bet 78.9852% of cossies have had this thrown away after it caused the knuckle dragging DIY spanner monkeys too much pain and grunts to throw it in the correct direction and put the nuts back in the correct order
Old 07-02-2012, 07:38 PM
DAN-Saff
DAN-Saff's Avatar
I remember fletch posting a picture of his engine with the bottom lugs of the head where the manifold bolts on ripped off from not having the support fitted.
Old 07-02-2012, 07:42 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
I have never used the support in 15 or so years of cossie ENGINE ownership
Steve
Old 07-02-2012, 07:49 PM
Cossie Sean
Seriousley?
never ever seen inlet manifold rip studs out on either my big power cossies or customers track/motorsport cars with none having this bracket.
pics would be awesome
Old 07-02-2012, 07:54 PM
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
no i had to cut mine in half and weld in a bit about an inch high!
Old 07-02-2012, 08:18 PM
BRAMMER
BRAMMER's Avatar
Right so it doesn't fit, strange that they even added a bracket that is no use with the standard bracket - they should have made it bigger
Right the only reason i want to fit one is to support the heavy plenum as many have uncovered the threads in the casting to be a bit dodgy
Old 07-02-2012, 09:24 PM
Cossie Sean
modded plenum needs modded bracket shocker
sorry
Old 07-02-2012, 10:21 PM
mk2cossy
mk2cossy's Avatar
Who runs a AIRTEC manifold? Are they a better fit/quality?
Old 07-02-2012, 10:28 PM
Moonstone Steve.
Moonstone Steve.'s Avatar
Its only a bolt on part..............trouble is you have to unbolt everything else around it to fit
Steve
Old 07-02-2012, 10:44 PM
Sonic Boom
Sonic Boom's Avatar
sorry
Steve
LOL
Rich
DAN-Saff
DAN-Saff's Avatar
Seriousley?
I've Pm'd him asking him if he still has the pic I'll post them when he gets back to me.
IMO the bracket does make a difference.
Old 07-02-2012, 10:59 PM
ajamesc
ajamesc's Avatar
its the same manifold so will have the same problems with fitment because other than the cast metal they use its just a copy of the hart one!
Old 08-02-2012, 08:53 AM
DAN-Saff
DAN-Saff's Avatar
Steve "fletchcossie" sent me the pics of his inlet. So you should really fit the bracket
Cheers Steve
Old 08-02-2012, 10:05 AM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
I have never seen that before
Steve
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Steve
I know
Steve
Old 08-02-2012, 10:30 AM
FletchCossie
FletchCossie's Avatar
No worries Dan to say I was shocked when I took the manifold off was an understatement I won't run my car without that bracket now
Old 08-02-2012, 11:22 AM
DAN-Saff
DAN-Saff's Avatar
I just noticed you said -
Then you say -
Seriousley?
The pics are above.
Old 08-02-2012, 12:07 PM
Cossie Sean
just said i havent seen it, didnt say it wasnt possible
if i take on off it goes back on
x
Old 08-02-2012, 01:50 PM
BRAMMER
BRAMMER's Avatar
Christ!!!!! Fletch i was more worried about the bolts being ripped out of the plenum but that is something i've never seen before - that confirms i will be fabbing a bracket up to fit this, maybe something that Auto Specialists may look at and sell with there kit
Old 08-02-2012, 04:06 PM
DAN-Saff
DAN-Saff's Avatar
Its a good thing i posted about the issue then went onto another board to contact the user ask for pics then come back on here to post them on here to prove it
No worries lol
Old 08-02-2012, 04:07 PM
FletchCossie
I was changing the inlet manifold gasket when I found this
Old 08-02-2012, 04:14 PM
DAN-Saff
DAN-Saff's Avatar
I bet that was an easy job getting the bolts off the bottom is a bit of a fucker
Old 09-02-2012, 08:09 AM
FletchCossie
Yep, I wasn't looking forward to it
Old 30-04-2012, 04:52 PM
4x4pete
4x4pete's Avatar
Just read this so where doesn't that support fit to? As fitted AS one today but having probs with the nearest brake pipe as well?
Old 30-04-2012, 05:18 PM
JamesH
JamesH's Avatar
Someone on here recently, did it even better than that! It had a Swedish plenum
Old 30-04-2012, 05:30 PM
BRAMMER
BRAMMER's Avatar
Some cars do have issues with the ABS block and the nearest pipe - you will have to go for a banjo fitting on the block - simple to do really just a hassle when you think your buying a bolt on part. But it was an issue when the Hart inlet was being fitted (the original to the AS inlet)
Old 30-04-2012, 05:36 PM
NEEDFORSPEED
NEEDFORSPEED's Avatar
bloody hell never seen that before crazy!
Old 30-04-2012, 06:20 PM
Cosnada
Cosnada's Avatar
Happened to Pig too when he had his YB'd yellow RS2K!!!!!!
Why not, instead of having a bracket underneath which we all know is a PITA Hang or support the plenum fom above from the rocker cover bolts just as the turbo is on the other side. I know nothing is 'off the shelf' for this and it might make the bufty boys cry but so would snapping ya inlet fanymold.
Just a thought and I am seriously considering it
Old 30-04-2012, 06:23 PM
Turbosystems
Super Moderator
Turbosystems's Avatar
it is not a support bracket it is a harmonic resonation damper
Old 30-04-2012, 06:28 PM
Cosnada
Cosnada's Avatar
Stick an NVH pad on it then - it will be fine
Old 30-04-2012, 06:30 PM
scoooby slayer
scoooby slayer's Avatar
Cheers Steve
fookin hell, was he full chat when it broke ?
Old 30-04-2012, 06:51 PM
4x4pete
4x4pete's Avatar
Thanks do know who has done this or a link with some pics? As I'm back working on it tomorrow?
Old 30-04-2012, 07:18 PM
polly_x
polly_x's Avatar
100% I would fit a support/resonation damping bracket using a big heavy Hart Inlet.
You probably get away with it on a standard inlet.
Had exactly the same happen to mine as the pics above. As Tony said its not ripped off its the vibration that causes the crack and head sections to break away.
Old 30-04-2012, 07:28 PM
Rsmat
300+
Rsmat's Avatar
Jesus mines going back on...!
Old 30-04-2012, 07:29 PM
Turbosystems
Super Moderator
all our engines are fitted with a harmonic resonation damper no matter what inlet manifold we are using
Old 30-04-2012, 07:31 PM
rickyg226
rickyg226's Avatar
hiya i no its nothinh to do with this but can some one tell me how i make up a thread up ? thanks yous
Old 30-04-2012, 07:35 PM
cossie4i+
TT T38 Power
cossie4i+'s Avatar
Best you sort one out for mine then please Tony before my next visit
When i get this bloody turbo
Steve
Old 30-04-2012, 07:38 PM
RWD_cossie_wil
RWD_cossie_wil's Avatar
You will need a tap & die set, is this for making a bracket?
Old 30-04-2012, 08:11 PM
Sonic Boom
Sonic Boom's Avatar
Here's the thread from when I fitted my Hart inlet to my 3 Door covers all the problems you might come up against.
Rich
Quick Reply: Hart / AS inlet support
